2006 Dakota P0129 Code
Old Aug 30, 2024 | 07:09 PM
Jim_2006Dakota's Avatar
Jim_2006Dakota
Default 2006 Dakota P0129 Code
Hello all,
2006 Dakota P0129 Barometric Pressure Too Low. Do you think its more likely the map sensor, or are there other likely possibilities? I thank you in advance for any input.
Old Sep 7, 2024 | 10:17 AM
dakotaff's Avatar
dakotaff
Truck stalling out or not starting?
If no, try and clear the code and see if it returns, sometimes it does not. (Clear with a scanner or disconnect battery for a while.)
Check this thread, map sensor replaced in last post, hopefully that was the cure.
