Wont turn over
Old Dec 20, 2025 | 07:46 AM
Dodgevity's Avatar
Dodgevity
Have someone hold the key in the crank position while you knock the starter body with a hammer.
If that works, here is how to replace the starter solenoid contacts. Easy job and better than AM starters which last a few years if you're lucky...
https://dodgeforum.com/forum/2nd-gen-dakota-tech/443252-starter-motor-compatibility.html
Old Jan 2, 2026 | 08:08 AM
Aldencrain's Avatar
Aldencrain
Originally Posted by Moparite
Does the relay "click" when you turn the key? You may need another person to listen as it can be hard to hear from the drivers seat. Try powering the small terminal on the solenoid and see if that works.
https://www.youtube.com/watch?v=_f6k...n8zvJB&index=1
I ordered an AM starter. It's sub-zero weather these days and I don't have a garage, so things are on hold for now.
Old Jan 12, 2026 | 06:47 AM
Aldencrain's Avatar
Aldencrain
Default new starter
Temps got above freezing last Wednesday so crawled under and swapped out the starter. that seems to have solved the starting problem. Now I can start working on why it won't idle. Getting a P0508 code, Idle Air Control System Circuit Low. I broke the clip off the wire connector, so I'm hoping it's just that it's not getting a good connection. I have a new connector on order.
Old Jan 23, 2026 | 08:02 AM
Aldencrain's Avatar
Aldencrain
All good now. Purring like a kitten. Until it doesn't. One day at a time.
