"spare" fuse/relay areas in fuse box
Old Mar 11, 2006 | 01:46 PM
Drakkon's Avatar
Drakkon
Default "spare" fuse/relay areas in fuse box
I was poking around in fusebox this morning and was going to the "spare" positions in the fusebox. Specifically positions 67&76. I got a project taht requires a relay, if i can just pop a relay into those and run a wire for 12V power out (only when truck is "on") it would be cool cause then i wouldnt have to have another wiring running to the battery and jerryrigging an acc lead like i did for my amp.
The the spare fuse areas (specifically 30/31) is there any power running to those or are they just spots you can hook a fuse to run a line from that would be like being inline to the battery?
Old Feb 27, 2009 | 09:27 AM
bluejeeptowrig's Avatar
bluejeeptowrig
Default from waaaaay back
did you ever get this figured out? I'm looking at using a 'spare' position for the relay for the driving lights I've added. But I can't see where to connect the wires? Mine is 05 Dakota. I do have the factory service manual with all the wiring diagrams, and it mentions those open spare spots are for user added options, but HOW!!!????
