setup for new dodge
Old May 4, 2006 | 02:22 AM
01dodge's Avatar
01dodge
Default RE: setup for new dodge
thanks for info guys, im just stumped , not sure to go with auto or manual. i have a 5 speed man. now with 130,000 plus, now .not sure if i want to give up on a stick. i like having the extra control over my truck.
Old May 4, 2006 | 02:30 AM
shocker88240's Avatar
shocker88240
ok, i have a 4speed 05 auto, so what gears do i have???
Old May 4, 2006 | 04:22 AM
snobrdrdan's Avatar
snobrdrdan
ORIGINAL: 01dodge
You get a 6 speed manual in the new Dakotas, if you didn't know (not a 5 speed anymore)
Old May 4, 2006 | 04:28 AM
snobrdrdan's Avatar
snobrdrdan
ORIGINAL: shocker88240
First off....with the 4.7 V-8 and an automatic....you have the 5 speed (545RFE) automatic transmission
Because you can only get the 4 speed automatic with the 3.7 V-6
Second.....the 4.7 V-8 automatic transmission automatically comes with 3.55 gears (which you most likely have)
3.92 is a $40 option which would be listed on the Window Sticker when you bought it
If you don't have that, check the inside of your glove box to verify what you have (should be a white sticker on the inside) or give your VIN to your Dodge parts counter & they can tell you
Old May 4, 2006 | 08:43 PM
shocker88240
ORIGINAL: snobrdrdan
thats odd, a guy i know runs a mechanic shop and he searched some program to find out my transmission and he said there was NO 5 speed automatic, only 4 speed....he even picked the V8 and everything......wow, thats crazy
Old May 4, 2006 | 10:59 PM
maxmax's Avatar
maxmax
Dan, Don't waste your time with Derrick. From his posts he does not have a clue about anything. I doubt whether he has a dodge anything.
Old May 5, 2006 | 12:45 AM
shocker88240
ORIGINAL: maxmax
stfu, how am i suppose to learn if i cant ask questions? fuggin douche
Old May 5, 2006 | 12:46 AM
jnellydodge's Avatar
jnellydodge
Ok to clear things up here, for a brand new 06' Dakota here are the powertrain options:
(SLT) Laramies only come with auto's
3.7 V6= 4 speed automatic or the 6 speed manual
4.7= 5 speed automatic or the 6 speed manual
4.7 H.O.= 5 speed auto ONLY
in your case (for towing) i would pick the Dakota SLT sport with the 4.7 V8 6 speed manual.......many years of loyal trucking for you.
Old May 5, 2006 | 01:28 AM
robscar's Avatar
robscar
When people say that their truck tows like mad, i wonder what their comparsion criteria are. I want to tow about 5,500 lbs, going up some hills. Going up hills from a stop also, and on some dirt roads. May do some long distance towing if the truck would be up to the task. I know it won't be a rocket, but I don't want to be going 25 up the long extended hills.
So, what are you towing, the weight, and road conditions.
We're going to test drive one tomorrow. The only one around with the full time transfer case.
Thanks, Rob
Old May 6, 2006 | 06:44 AM
snobrdrdan's Avatar
snobrdrdan
You DEFINITELY have the 5 speed automatic
(I had the same tranny in my 2002 SLT Club Cab 4.7....so it's been around for like 5 years now)
It has 5 gears....but when you're driving you'll only feel it shift 4 times.....1st to 2nd, 2nd to 3rd, 3rd to 4th, 4th to 5th
The major difference is that it's also got two 2nd gears........one if for upshifting & the second 2nd gear is for when it downshifts (they have different ratios). So when you punch it, it downshifts to a different 2nd gear that gives you a more aggressive response.
Hope that makes sense
Here's more info on the tranny & shows the two 2nd gears I was talking about:
http://www.getahelmet.com/jeeps/tech/545rfe/
