setup for new dodge
im looking to get 06 dakota, i do alot of pulling & soon to b pulling car trailer w/neon 4 racing. im looking to get an extend cab, 4.7 4x4,tow package, sport . i have 2001 w/ standard trans. now and pulls great. any sugg. on setup ,rearend etc. on 06
If your really bent on a dakota, for towing, opt for the 4.7 HO (high output) motor. Its a bit more expensive, but it'll be worth it. That setup will give you the 3.92 rear end with the 5 speed trans. Best set up the dakota has to offer for towing/power. It actually puts the dakota into full size territory, and suprasses the Toyota Tundra ha ha ha. I see you want to get a sport, if you really wanna dress it up and have the cash, try to get one with the Dakota Appearance Package.
You only get the higher output numbers on the 4.7 H.O. when you run Premium fuel though
You don't have to run Premium, but you get less performance when you use regular unleaded gas
And I put 4.10 gears in my truck (from 3.55) and it would be perfect for towing (though I don't).....doing 70mph the RPMS are at about 2300-2400 (2WD). So the 3.92 gears will get the job done for you.
On the new Dakotas they also have a Tow/Haul mode (on the auto shifter) now anyways, which changes the shift points as well for towing.
The "heavy duty service group" automatically comes with the Tow package, by the way
sdsdsd, u have auto or manual trans.? from the info i got , u cant get 3.92 w/ manual trans.
Trending Topics
ORIGINAL: 01dodge
You are correct, you can't. If you want the manual trans you have to have the 3.55 (which sucks)...and you can only get it on the ST or SLT, not the Laramie. Also, the 4.7 HO is not available with the manual trans, only the 4.7 (which is what you want anyways i take it?)
