Attention 2005 Dakota Owner's 1
Old Jul 28, 2006 | 02:18 AM
Chad05's Avatar
Chad05
Default Attention 2005 Dakota Owner's 1
NHTSA Investigating Dodge Dakota and Durango
Nov 1, 2005 | www.consumeraffairs.com
The National Highway Traffic Safety Administration (NHTSA) is investigating almost 500,000 Dodge Durango SUVs and Dodge Dakota pickup trucks because of a possible loss in steering control.
NHTSA reports that the agency has received several reports of loose steering shafts and separation because of loose or missing coupling bolts in the vehicles.
NHTSA said there have been no reports of crashes or injuries but ConsumerAffairs.com has received several reports of accidents caused by steering problems.
The preliminary investigation will involve more than 467,000 vehicles, including the 2004-05 models of the Durango and the 2005 model of the Dakota.
There have been no crashes or injuries linked to the steering problem, according to NHTSA and DaimlerChrysler AG is cooperating with the investigation.
OH WOW MORE PROBLEM'S AND WHO SAID THERE WERE'NT PROBLEMS WITH THE DAKOTA!!!
Old Jul 29, 2006 | 08:10 AM
graythang's Avatar
graythang
Default RE: Attention 2005 Dakota Owner's 1
The problem is the codes don't say anything BAD. OK good accuse as any.
Old Jul 29, 2006 | 09:40 PM
Dak_in_Black's Avatar
Dak_in_Black
An investigation does not mean a whole hell of a lot. There are just looking into the possibility that something may be wrong.
AFAIK, there are only two recall notices out on the 05, that's it.
Make : DODGE Model : DAKOTA Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
NHTSA CAMPAIGN ID Number : 05V460000 Recall Date : OCT 04, 2005
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Number Of Units Affected : 256409
Summary:
ON CERTAIN PICKUP TRUCKS, SPORT UTILITY AND PASSENGER VEHICLES EQUIPPED WITH 42RLE AUTOMATIC TRANSMISSIONS, THE CUP PLUG THAT RETAINS THE PARK PAWL ANCHOR SHAFT MAY BE IMPROPERLY INSTALLED. IF THE SHAFT MOVES OUT OF POSITION, THE VEHICLE MAY NOT BE ABLE TO ACHIEVE 'PARK' POSITION.
Consequence:
IF THIS OCCURS AND THE PARKING BRAKE IS NOT APPLIED, THE VEHICLE MAY ROLL AWAY AND CAUSE A CRASH WITHOUT WARNING.
Remedy:
DEALERS WILL INSPECT THE TRANSMISSIONS AND INSTALL A BRACKET TO ENSURE THE PARK PAWL ANCHOR SHAFT IS RETAINED IN THE PROPER POSITION. THE RECALL BEGAN ON NOVEMBER 28, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. E14. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236; (TTY:1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
NHTSA CAMPAIGN ID Number : 05V002000 Recall Date : JAN 03, 2005
Component: AIR BAGS:SIDE/WINDOW
Potential Number Of Units Affected : 1142
Summary:
ON CERTAIN PICKUP TRUCKS EQUIPPED WITH THE OPTIONAL SIDE CURTAIN AIR BAG, THE CURTAIN FASTENERS MAY NOT HAVE BEEN PROPERLY TIGHTENED.
Consequence:
THIS COULD RESULT IN AN IMPROPER SIDE AIR BAG CURTAIN DEPLOYMENT IN CERTAIN SIDE CRASH CONDITIONS, WHICH CAN INCREASE THE RISK OF INJURY TO VEHICLE OCCUPANTS.
Remedy:
DEALERS WILL TIGHTEN THE SIDE AIR BAG CURTAIN FASTENERS TO THE PROPER SPECIFICATION. THE RECALL BEGAN ON JANUARY 17, 2005. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D57. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
