clutch fans?
RE: clutch fans?
if you wish to remove your clutch fan and replace it with a upgrade electric, go ahead, just remeber they work off of a 40/45 amp fuse.this will draw a lot of power from the management control box. so if you are running aftermarket component, stero, amps, ect. you may need to upgrade some wires and things.but as far as the clutch fan goes. mostly used in stop and go traffic, on the highway very rarely unless you are standing on the throttle all the time. most people that tow go with the electric, it gives them a little more umph when getting up and going
RE: clutch fans?
ORIGINAL: sdsdsd
Removing your clutch fan is looking for trouble. This is designed to turn the fan when it is needed. the fan turns of and free wheels at highway speeds. Hiway is when you don't need extra cooling from your fan.
RE: clutch fans?
ooo i cant believe its taken me this long to ask! what kind of sound systems do you guys have and HOW did you get them? i relly miss my dual 12" 1000 watt subs from my old car...all i have now is alpine speakers...and even they barely fit. is this gonna cost a fortune in custom work?
RE: clutch fans?
I measured the radiator it's around 23x18 Flex-A-Lite makes the 180 Black Magic Xtreme,I have a Proform 15 inch that very similar to the Black Magic 150,I haven't installed it yet but here's the links for both,I'm not sure if they have a dual setup that fits our trucks.http://www.flex-a-lite.com/auto/html...c_x-treme.html,,,,http://www.flex-a-lite.com/auto/html/black-magic.html,,,,,,,,,,Here's a pic of my Proform set up.
[IMG]local://upfiles/39512/9D8CEC9BDE0C4D70B09EE5461CCC2A9D.jpg[/IMG]
RE: clutch fans?
I visited those links for the Elec Fans and nothing says anything about Gains of HP or Torq.
How much of a Gain are we talking about here?
These fans http://www.flex-a-lite.com/auto/html/black-magic.html seem to be for a 5.0 Mustang so all the mounting hardware will be for a 5.0 Mustang,.. How does this all play into the 2005 Dakota?
Do you have to then worry about the Serp Belt? I mean if you remove the Fan wont the Belt be to Big then?
D05D
D05D
