05 Dak wind noise
Old Oct 9, 2006 | 11:03 PM
skinsfan's Avatar
skinsfan
Default 05 Dak wind noise
05 quad cab Dak, notice some noise appears to be coming from the right upper windshield area. I have checked and no leaks and no air comming through. Maybe noise from the antenna moving around or the vent guards on the door? Only on the rt side and only at highway speeds (approx 65-70 mph). Maybe just a truck noise, but figured I would ask.
Old Oct 10, 2006 | 12:26 AM
ETXDak's Avatar
ETXDak
Default RE: 05 Dak wind noise
Do you have hood deflector on,I put one on my 03 Silverado it make a muffled sound like popcorn poping,turned out several other people were having the same problem it was deflecting air into the windshield causing the sound at highway speeds,tried moving it around that didn't help,ended up removing it.
Old Oct 10, 2006 | 02:58 PM
skinsfan's Avatar
skinsfan
yes, I do have a bug guard on the front. The noise is very much like popcorn. Only on the right side thought? Thanks for the info, I will move it around and see if it helps.
Old Oct 10, 2006 | 03:27 PM
ETXDak's Avatar
ETXDak
My noise came from the upper right side also.
Old Oct 10, 2006 | 04:09 PM
superdak05's Avatar
superdak05
no wind noise here. had the dak up yo 118 on the highway , just that stupid frt end sailing into the night
Old Feb 19, 2007 | 11:53 PM
skinsfan's Avatar
skinsfan
mystery solved, just has the windshield replaced and no more noise......
Old Feb 20, 2007 | 10:22 PM
skinsfan's Avatar
skinsfan
Got nailed by a rock...problem now solved. I tried taking off the antenna, taking off and on the bug guard and the window vent shades. Was driving me crazy
Old Feb 20, 2007 | 11:08 PM
Dusty's Avatar
Dusty
Chryslerdidn't seal up these trucks very well. I had a air/water leak from my back window and I had the dealer reseal it under warranty.
