drag strip et's
Old Nov 28, 2006 | 03:18 PM
ETXDak's Avatar
ETXDak
Default RE: drag strip et's
Superdak you running the KRC 200/212 cams?are you running a modded throttle body?I'd love to go that route,has your mpg taken a big hit?
Old Nov 28, 2006 | 09:52 PM
superdak05's Avatar
superdak05
206 cams with the stock tb. lost about 2 miles to the gallon over all, stock was getting 20/22 on highway and around town 18/19. but also now that it is getting alot colder out in ct, mileage has dropped to about 16.5/17 over all. plus i cant seem to keep the back end from spinning down the street. corp.9.25 with the 3.55. plus this is with the stock wranglers
Old Nov 29, 2006 | 12:53 AM
lownslowneon's Avatar
lownslowneon
how much do those 206ers cost?...
Old Nov 29, 2006 | 01:19 AM
superdak05's Avatar
superdak05
700.00 for both cams. and another 400.00 to have them installed. .well worth the money. you figure a good nos kit will run you 600.00 and you might take a chance at detonating the motor. its better to be safe then sorry. also the cams wont void warrenty. just dont tell them you installed them. if you go to dealer with the nos solenoids still hooked up, then there might be a problem, my truck is coming up on its 30000 mile check up. i will see what the dealer says.
Old Nov 29, 2006 | 01:28 AM
turbot_bird's Avatar
turbot_bird
let us know, I might do cams down the road. who all makes cams for these things?
Old Nov 29, 2006 | 01:40 AM
ETXDak's Avatar
ETXDak
KRC Performance,,,,,,http://krcperformance.com/newcontent/47page.html
Old Nov 29, 2006 | 02:17 AM
superdak05's Avatar
superdak05
krc is the best for this stuff .they dyno pages and everything
Old Nov 29, 2006 | 02:42 AM
lownslowneon
I'd probably install it myself..... we'll see if I can convince the wife that her truck needs some cams
Old Nov 29, 2006 | 03:41 AM
superdak05's Avatar
superdak05
forget about installing them yourself, if you dont get the timing just right for both cams you will be in trouble. i had a good shop do mine and it was about 5.5 hours. if you do it yourself it could take most of the weekend
Old Nov 29, 2006 | 10:41 AM
ETXDak's Avatar
ETXDak
KRC throttle bodies are high $,I heard alot of good things about this guy,probably if I ever get around to it I'll order from,,,,,,,http://www.thefastman.com/Throttlebodies47.asp
