HID conversion Kit - BIG DIFFERENCE!
Old Feb 13, 2007 | 06:59 AM
  #21
SuperNotch's Avatar
SuperNotch
Default RE: HID conversion Kit - BIG DIFFERENCE!
right on ya ill try that.. also with the 9007 kit for the fogs it was so simple to hook up like just snap a clip into the stock clip, but not the H13, it only has a positive and neg wires to go into this stock clip with 3 little holes, now i can get the lights to turn on but now all i have is jammed points in this plug, with vehicle vibration they may come out if there any clips or anythig i can buy to make this eaier did u have this prob
Old Feb 13, 2007 | 02:03 PM
  #23
jimboscomp's Avatar
jimboscomp
Yes I did have that problem as well with just getting tabs to stick in the old housing. I myself figured I was going to keep them since my new kit I bought for $250 works really well. I just cut the wires and spliced them together inside some heatshrink tubing, so I dont have a problem with them coming loose. If you dont want to cut the wires, use liquid electrical tape to hold the pins inside of the harness, it will hold them in place really well but if you want to remove them, the tape will just rip off
Old Feb 13, 2007 | 05:07 PM
  #24
shnormo's Avatar
shnormo
I did the same thing for my 2001 S10.
