06 Auto Transmission sliding in to OD?
Old 01-04-2007 | 12:20 AM
ETXDak's Avatar
ETXDak
Default RE: 06 Auto Transmission sliding in to OD?
For what it's worth,,,,,,,,,Only certified ATF+4 is recommended for service of Chrysler Group vehicles. The use of automatic transmission fluids other than ATF+4, including those claiming to be like ATF+4, could result in lower levels of performance and jeopardize transmission life.,,,,,,,,,,,,,,,,,,I'm not saying anything bad about Amsoil, personally I wouldn't want to argue the point with DC over warranty work.JMO
Old 01-04-2007 | 12:32 AM
Glk21C's Avatar
Glk21C
AMSOIL ATF is compatible with whatever the DC spec number is. You are not taking a risk using it. 160,000 on one tranny and 25,000 on this one is reason to believe this. It's the best trans fluid you can buy
Quick Reply: 06 Auto Transmission sliding in to OD?
