My Dakota
Old Jan 10, 2007 | 01:39 PM
Kerrbear219's Avatar
Kerrbear219
Default My Dakota
This is my truck before I did anything to it.....the day it came home.
Here she is now (excuse the dirt it is winter after all)...
Old Jan 10, 2007 | 07:17 PM
05bluedak's Avatar
05bluedak
Default RE: My Dakota
i have a fewquestions. is it just a hood scoop for looks or does it actually function? where did you get it from? and if it is functioning is there something built in so rain doesn't get into the engine? I like the look, good job on your truck.
Old Jan 10, 2007 | 07:31 PM
Kerrbear219
Thanks it's purely ornamental. i purchased it from the dealer and they installed it. i wish it were functional but no such luck. Thanks again.
Old Jan 10, 2007 | 08:03 PM
05bluedak's Avatar
05bluedak
where did you get it from though i can probably bring it to a shop around here and have them cut my hood. then just gotta buy a air filter or something. I'm just going back and forth on a hood for my truck right now this is the one i'm thinking its just quite pricy. http://www.keystonerestyling.com/cgi...alogno=GHD-206
Old Jan 10, 2007 | 09:38 PM
Glk21C's Avatar
Glk21C
looks like the same hood that comes with the 06 R/T
Old Jan 10, 2007 | 10:16 PM
Kerrbear219
I got it from Artioli Dodge in CT....that was the car dealer I bought the truck from and the hood scoop.
And yes I do believe it is the same as the one from the R/T ...that was what made me want one in the first place.
Or you can purchase it online at Autotrucktoys.com
It is the :
OEM Dodge Dakota Bolt-on Single Snorkle Hood Scoop for Dodge Dakota 05-UP
http://www.autotrucktoys.com/dodge_d...5102C1968.aspx
It only comes in certain colors or primed to be painted.
Old Jan 10, 2007 | 10:31 PM
jonnymagnum's Avatar
jonnymagnum
nice truck
it wouldnt be that hard to make it functional
Old Jan 10, 2007 | 10:33 PM
Kerrbear219
OH please share..how could i do that?
Old Jan 10, 2007 | 10:41 PM
Night_Runner's Avatar
Night_Runner
what material is that made out of. looks good but it would look even better if you could smooth it out where it meets the hood. and wow thats bolt on? thought it was like one of those stick ons. no offense, still looks good, just would look better if there is a way to mold the 2 together
Old Jan 10, 2007 | 10:59 PM
jonnymagnum
It's pretty easy... all you have to do is cut the front opening of your hood scoop out. and then put some gutter guard or something like that in the opening, so no bugs and other stuff can get in there.
then I would cut a 4" round hole in the hood somewhere. I'm not too familiar with where everything is on the gen 3 dak. but you could run a hose from the hole in the hood to your air filter.
OR
get a 14" round open air filter and put it on top of your throttle body(unless yours are sideways) and make a box around it and seal it off to the hood.
OR
put a sheet of aluminum on the bottom of your hood. then you can cut a 4" hole in the aluminumat the front where you stock air filter is and run a hose down to it.
those are just some suggestions, maybe someone has a better idea.
also, dont forget to drill a small pin size hole in the front of the scoop to let water drain out. or else your scoop will fill up with water.
