Building my own intake, putting together a DIY.
Old Jan 31, 2007 | 07:40 PM
Chris's Avatar
Chris
Default RE: Building my own intake, maybe.
You can search for things like this because it has been covered many times before. You have the right idea. Simply block off the filter from the engine heat with a heat shield, and make sure that the inside of the tubing is smooth, without any obstructions.
Old Feb 1, 2007 | 04:43 AM
snobrdrdan's Avatar
snobrdrdan
Yup...it can be done easily & cheap
It just isn't pretty....lol
Old Feb 1, 2007 | 02:24 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
honestly, lol this might sound silly to some people but i need "official" stuff. I need brand name K&N plastic intake that looks like it could of came with the truck. I couldnt have a custom made intake kit unless I wanted to feel like Ronald McDonald. Did you see some pics of the plastic series K&N kit installed? This looks high quality, because it really is. Thats what I'd want to deal with under MY hood. IMO. I mean if we are talking about a 91 accord with rust holes in it you could make and intake out of a paper towel core for all i care, but a new truck?
Old Feb 1, 2007 | 06:48 PM
luvmydak's Avatar
luvmydak
ORIGINAL: ericemery
quick question that I cant find an answer to... what coupler are people using to connect to the T.B. and isn't there a sensor that I should be thinking about?
If you still insist on going the DYI route, check out the plumbing dep't. of Home Depot or Lowes. Both have these rubber couplers with the adjustable clamps on them. They come in all sizes and you should be able to find what you need. Measure your TB o.d. opening which would accommodate one end of the couplerand the o.d. of the thin wall tubing you intend to use. The IAT sensor is what you are thinking of-very inportant you install this in the tubing about 3-5" before the TB connection. With the tubing off the truckdrill a 3/4 hole in the tubing at that point and use the same grommet. Be sure the inside of the tubing is perfectly clean.The sensor is VERY delicate. Be careful removing and reinserting. All this work should be done with the NEG cable disconnected. Before reconnecting batt. cable make sure all connections are air tight and then reset PCM by turning ignition to run and holding for 15-20 sec. while the neg.cable is still disconnected THEN reconnect batt. cable. Don't forget the heat shield. Bottom line: if you have ANY doubts about doing this DYI, get the K&N system, a lot less of a headache.
Old Feb 2, 2007 | 07:06 AM
snobrdrdan's Avatar
snobrdrdan
ORIGINAL: MonkeyWrench4000
I definitely agree thatthe K&N looks bad *** and theyspent the money and R&D in developing it.....it's good for like 9 rwhp
If a company spends all that money in making a product for our truck and no one buys it......that means there is no market for parts for our truck and no one is going to bother making stuff for it. Just something else to think about.....
You gotta pay to play
Old Feb 2, 2007 | 11:58 AM
luvmydak's Avatar
luvmydak
Snobrdrdan has a point. Realistically anybody looking for real performance can't expect to throw bathroom plumbing materials into their engine bay, get it dyno'd and say wow, what a kick a** system. Get real! Spend the money or leave it stock.
Old Feb 2, 2007 | 12:41 PM
snobrdrdan's Avatar
snobrdrdan
Thank you!!!
luvmydak has the right point there
Save the Home Depot intake idea, and just save up the money for the K&N intake...I think it's like $220 SHIPPED on ebay, which might be a lot of money to some people I know. But just do it right one time instead of going thru the work/trouble of making one to realize it looks hideous and you wasted your time/money.
