I need to know if I am right
Old Feb 9, 2007 | 08:05 PM
superdak05's Avatar
superdak05
Default RE: I need to know if I am right
i am running the napa stat and yes it works. just remember to cut a litle notch in it like the 195 so it fits. it is the same stat that i was running in my 97 5.2
Old Feb 10, 2007 | 02:56 PM
superdak05's Avatar
superdak05
all you need to do is drain the radiator about 2 gallons. when you unbolt the housing for the stat becarfull not to get fluid in eyes.some will drain out but not much less than a pint. also the drain **** is only cheap plastic so dont break it. here is a pic of the stats the 195 is on the left and the 180 in the middle
[IMG]local://upfiles/31284/0BD442AF242249C199709397DC1DCF93.jpg[/IMG]
Old Feb 10, 2007 | 03:13 PM
DakotaStone's Avatar
DakotaStone
Sounds like you might as well flush it while you're at it. I'm going to go ahead and do that myself when I change out the t-stat.
Old Feb 11, 2007 | 01:40 AM
superdak05's Avatar
superdak05
just good enogh so the rubber gasket that you take of the factory stat fits. mine is not perfect so i turned the gasket inside out and cut the rubber nipple off. but becareful if you do this not to cut through the gasket
