Trans dipstick
Old Feb 11, 2007 | 08:42 PM
05dak3.7's Avatar
05dak3.7
Default Trans dipstick
I cant seem to locate the trans dip stick,,Also has anyone changed there rear diff fluid yet??
Old Feb 11, 2007 | 10:30 PM
turfgrass's Avatar
turfgrass
Default RE: Trans dipstick
If I remember correctly the trans dipstick is to the left of the oil dipstick, the handle is a circle, in your signature it is the yellow spot behind the blue clamps on your CAI left of the dipstick..
Rear diff has not been changed on mine. So I can't help you there
Old Feb 12, 2007 | 12:26 AM
luvmydak's Avatar
luvmydak
Hmmmmm. Why does the question by 05dak3.7 not surprise me? When I first popped the hood on my Dak. it must have taken me........ let's see, about .05 seconds to find the trans. dipstick.
Old Feb 12, 2007 | 03:01 PM
Tani1500's Avatar
Tani1500
ORIGINAL: luvmydak
does it matter? answer the question or dont answer! everyone bitching about him, why dont u all stop ragging on the guy
Old Feb 12, 2007 | 03:37 PM
tcv's Avatar
tcv
I changed the rear diff oil at about 8,000 miles. I read a interesting article about this. Basically the amount of wear in the first 8,000 miles (break in period) makes it worth replacing the fluid. They found that if you did change it that the amount of wear is minimal over the next 100,000 miles (actually less than what will be present over the first 8,000 miles). If you don't the amount of wear as the miles go up becomes very excessive. Changing it was n't all that hard, but slightly messy. It would be so nice if there was a drain plug.
Old Feb 12, 2007 | 03:53 PM
05dak3.7's Avatar
05dak3.7
Hey luvmydak..It was just a question..
Old Feb 12, 2007 | 04:38 PM
MoparMafia's Avatar
MoparMafia
you guys should do what i did. drill and tap a hole for a 1/2" bolt for a drain plug. it works awesome and saves time
Old Feb 12, 2007 | 04:42 PM
bkjtimp's Avatar
bkjtimp
How would you change the rear diff fluid w/o that newly drilled drain plug? Howz it normally done?
Old Feb 12, 2007 | 04:56 PM
MoparMafia's Avatar
MoparMafia
you'd have to remove the rear diff cover. very messy
Old Feb 12, 2007 | 04:59 PM
Chris's Avatar
Chris
You can syphon out the fluid through the filler plug. Once you get our as much as you can, then you open the rear dif. This makes the project much cleaner.
