Fuse Question
Old Feb 21, 2007 | 10:40 AM
rick4dak's Avatar
rick4dak
Default Fuse Question
Is thee a fuse that only works for the seat belt alarm ? Before I start taking fuses out one at a time, I wonder if anybody else has already found the proper fuse. Or is there a connector that I can disconnect ?
Old Feb 21, 2007 | 11:24 AM
turbot_bird's Avatar
turbot_bird
Default RE: Fuse Question
I asked my dealer about it and they said there is nothing that can be done, she said in hers she just took the middle belt and buckeled it into that slot lol, I also double checked the fuses and i cant find one just for that.
Old Feb 21, 2007 | 11:58 AM
superdak05's Avatar
superdak05
go to the junk yard and cut up a belt that would fit in the slot. dodge belts have to be compatible
Old Feb 21, 2007 | 04:24 PM
mb18's Avatar
mb18
You can actually disable the seat belt alarm w/out pulling any fuses. There's a procedure in the manual that details this; I would advise you to check that. Going from memory, though, all you need to do is start the truck, buckle and unbuckle three times within 10 seconds, shut the truck off, then start it up again and you should be good. i might be off on some of the details, but that should be pretty close for you. I can check tonight when I get home, if you'd like.
Old Feb 21, 2007 | 11:48 PM
Night_Runner's Avatar
Night_Runner
will you have to do this every time or just once. also, even if you do buckle your belt, will the light turn off now? also, can you do it again to make it beep again
Old Feb 22, 2007 | 01:13 AM
Flame_Red_4x4's Avatar
Flame_Red_4x4
You only have to do it once. i did it the day I got my truck. The light is on, but no chime. The light does go out if you buckle up. And yes the procedure can be done again to undo the doings.
Old Feb 22, 2007 | 11:19 AM
rick4dak's Avatar
rick4dak
Thanks for the info. I'll try it as soon as I get off work today.
Old Feb 27, 2007 | 07:38 PM
rick4dak's Avatar
rick4dak
I finally got around to disabling the seatbelt alarm. Turning the ignition on/off three times didn't shut the alarm off so I read the manual. Maybe 2005 is different than 2006.
1) Sit in the truck with seatbelt buckled
2) Start the engine
3Wait for the seatbelt light go go out
4) Unbucle/buckle three times ending with the seatblet buckled
A chime sounds signaling the seatbelt alarm is disabled.
