A couple questions.
I recently bought a 3.7l Dakota and was wondering if anyone makes a Shaker hood for these? I've seen them for the 4.7, but not the 3.7. Does anyone know where I can get that hockey stick decal that comes on the R/Ts?
If you've seen a shaker hood for the 4.7, then you have your answer. As far as I know, the hoods are exactly the same. Is the shaker hood a functional air scoop? If not, then it should definitely be universal.
Ive only seen em for the 4.7 as well..It should be universal though??!!??
Trending Topics
ORIGINAL: Flyhalf
Well if its an OEM add on then its not a functional scoop, they only make functional scoops for the viper SRT-10 and soon the Caliber SRT-4, the rest just have a nice piece of black plastic in the scoop...so it should be universal.
The hood on the RT is not a shaker and is non functional. A shaker is called that because the scoop part is attached to the engine that fits through a hole in the hood, when you rev the motor the scoop would move independent of the hood hence shaker. Check out theold Ponti TAs. It doesn't look functional though.
[IMG]local://upfiles/39512/C926F9FCDCD64A7683C8E7A29F590BAD.jpg[/IMG]
