3rd Gen Durango 2011+ models
NAV volume is too weak
Old Apr 19, 2011 | 01:06 PM
DNAsiRNA's Avatar
DNAsiRNA
Default NAV volume is too weak
Hi, I just bought a Durango Crew with 430N plus NAV. I found the volume of direction voice indication is too weak and can't find the way to adjust it. If I adjust music volume, I do hear the louder voice, but music is too strong.
Any way to do it? Thanks.
Old Apr 19, 2011 | 07:55 PM
gamoon's Avatar
gamoon
Default Volume
I have a Citadel with the same issue and have not found a way to change it either.
Old Apr 20, 2011 | 02:04 AM
IndyDurango's Avatar
IndyDurango
Take it back for warranty repair claiming it is "broken".
When they swap it out, it is not likely they will use the 430 and instead will swap it back in with the 73X.
IndyD
Old Apr 21, 2011 | 02:48 PM
DNAsiRNA's Avatar
DNAsiRNA
Google gives me the answer. Turn the volume **** when voice indication is playing. The Nav will memorize the setting next time.
Old Apr 23, 2011 | 06:17 AM
gamoon's Avatar
gamoon
Adjusting the volume when the NAV directions are active works great problem solved for me.
Old Apr 23, 2011 | 10:51 AM
D3_USCG's Avatar
D3_USCG
You can also press the speaker icon in the upper right corner of the nav screen and use the **** to turn up the nav volume.
Old Apr 24, 2011 | 08:19 PM
gamoon's Avatar
gamoon
Default Nav vol
I don't see a speaker icon?
Old Apr 24, 2011 | 11:44 PM
D3_USCG's Avatar
D3_USCG
I have the 730n in my Durango. I didn't think the nav program would be any different between the 430n and the 730n but I guess so.
Old May 2, 2011 | 01:59 PM
c_l_phillips72's Avatar
c_l_phillips72
I had the same problem but it's VERY easy to fix. The NAV has it's own volume setting, different from the stereo volume setting. Just turn up the volume using the steering wheel volume control at the time when you should be hearing the NAV audio.
