3rd Gen Durango 2011+ models
IOD Fuse connection
Old May 2, 2011 | 07:39 AM
cbrrider012's Avatar
cbrrider012
Default IOD Fuse connection
Anyone know where the IOD fuse connection is on the 2011 Durango? Another guy on here at the same problem I am having where the Mediacenter turns off every once in a while and said that the Dealer tightened the IOD connection and it eliminated the issue. Help me find it!
Old May 2, 2011 | 10:06 AM
coldsteel's Avatar
coldsteel
Main IOD fuse is J13 in the box under the hood (60Amp yellow)
Old May 2, 2011 | 01:58 PM
cbrrider012
I found the IOD Main Fuse. It has a white sleeve around it in the fuze box. The fuse was not even pressed all the way down. Was kind of just sitting in the slots. Hope that fixes my issues!
Old May 3, 2011 | 01:53 AM
IndyDurango's Avatar
IndyDurango
That's what happens when factory union workers at the assembly plant were allowed to smoke pot on their lunch breaks.
Reportedly, most of those guys got fired after the press got ahold of the story. However not before many of the early Ds went through production.
I am not surprised at all that there are misc silly issues here and there. Attention to detail and doing your best work when high usually don't go hand in hand.
Old May 9, 2011 | 04:00 AM
maherm's Avatar
maherm
Talking
Don't forget to press all the fuses in the fuse box, It is a must with any chrysler and dodge vehicle that I have bought in the past 6 yrs.
Old May 11, 2011 | 10:36 PM
jtiller's Avatar
jtiller
I had the same problem with mine, media center turned off after crossing railroad tracks. Found the fuse loose, tightened all of them and everything is great now.
Old May 18, 2011 | 12:14 PM
pmichos's Avatar
pmichos
Default fuse problem
Just so everyone knows the fuse problem is not from the factory. the fuse for the media center is installed at the dealership. It is part of the dealer prep when the car is received from the factory. If it is not installed properly it means that the dealership has incompetent techs working on the car!
Old May 19, 2011 | 07:34 AM
coldsteel's Avatar
coldsteel
Incompetent techs! No way! That would never happen. I thought they were paid so well.
