3rd Gen Durango 2011+ models
Axle ratio - 3.45 vs 3.09
Old Dec 30, 2011 | 07:41 AM
chargeme11's Avatar
chargeme11
Not all V-8 durangos some with the 3.45,, it depends how it is ordered,, My r/t has the 3.45,, but the crew I drove had the smaller ratio...
Old Dec 31, 2011 | 12:55 AM
ZCR1's Avatar
ZCR1
Originally Posted by happyfirst
seems to me it's time for someone to invent a dual ratio setup that a driver could switch? Have an eco button to engage 3.09?
Kind of like this, huh?
http://www.gearvendors.com/index.html
Old Dec 31, 2011 | 09:29 AM
happyfirst's Avatar
happyfirst
Originally Posted by shrpshtr325
not true at all OD is just a lower gear ratio than drive (lower in the sense that it makes the engine spin lower and the driveshaft/wheels spin faster.
what you are referring to is torque converter lockup, and it will happen in lower gears under the right conditions (no it doesnt happen often)
Yup, correct. I finally decided to do some research and you're right, a lockup torque convertor is what I had described.
Old Dec 31, 2011 | 09:33 AM
happyfirst's Avatar
happyfirst
Originally Posted by ZCR1
Interesting. But a lot of $$$$$.
Old Apr 6, 2014 | 09:57 AM
WannaV-8's Avatar
WannaV-8
This is an old thread, but is there a 3:45 pumpkin available for the V8 Durango? If I could swap mine out, I could bring this 5/6 speed into more usable territory. Don't want to change to a 2014 just for the 8 speed as I love everything else more on my '13 (shifter, front end, storage, buttons for access etc.)
My second gear, 1.67 is equal to the new 8 speed 4th gear!
My first at 3:00 is nearly same as 8 speed 2nd gear 3.14
Old Apr 7, 2014 | 11:38 AM
Trace3rd's Avatar
Trace3rd
3.45's not enough either, they all needed the 3.92 option available for towing, like the trucks have, and it should have been standard on the RT's IMO. The trucks with that option run great, especially the one with the 8spd I test drove.
