3rd Gen Durango 2011+ models
Anyone try an axle swap?
Old Apr 6, 2014 | 11:22 AM
WannaV-8's Avatar
WannaV-8
Default Anyone try an axle swap?
About the only thing I'm not wild about is the 3:09 axle ratio in my 2013 R/T. Haven't seen a 3:45 for the V-8, but came across a 3:44 pumpkin available on the JGC. They list a 195 mm, same as Durango. Wonder if they could be swapped out?
With the 6 speed/compared to the 8 speed I am essentially starting in 2nd and going to 4th and then 6th. (my 1st, 2nd and 3rd--I'm using 5 forward as 3rd gear is a passing gear only.)
Other than the new 8 speed, I prefer the layout on my '13 vs. the '14.
Old Apr 6, 2014 | 12:06 PM
pjw1967's Avatar
pjw1967
I'm pretty sure that all R/T's and maybe all 2013 Hemis came with the 3.45 axle ratio as standard.
Old Apr 6, 2014 | 01:42 PM
WannaV-8's Avatar
WannaV-8
Default 3:09
If you go here……..all you'll find for 2013 is the 3:09. Probably for CAFE standards.
http://www.factorychryslerparts.com/...8191853AA.html
Old Apr 6, 2014 | 05:28 PM
FSTDANGO3's Avatar
FSTDANGO3
From my build sheet
3.45 Rear Axle Ratio
230MM Rear Axle
Old Apr 6, 2014 | 06:40 PM
Wash Man's Avatar
Wash Man
I have 3 R/T 2014 build sheets from when I was shopping. 2 RWD and 1 AWD. They are all 3.09
Old Apr 6, 2014 | 06:51 PM
pjw1967's Avatar
pjw1967
FSTDANGO3, I looked at my build sheet as well. Code DLKS "3.44 Overall Top Gear Ratio". Do you have 3.45 against the same code?
Old Apr 6, 2014 | 06:55 PM
pjw1967's Avatar
pjw1967
Yes, all the '14's are 3.09. I believe the discussion centers on '13's with the V6 at 3.09 vs the V8 at 3.45.
Old Apr 6, 2014 | 08:01 PM
FSTDANGO3's Avatar
FSTDANGO3
Mine sais 3.45 ratio front and rear.
I Believe it was an option and part of a certain numbered pkg.
STEVE
Old Apr 6, 2014 | 08:29 PM
WannaV-8's Avatar
WannaV-8
Interesting. Be nice if I had that option. Is there a way to discern axle ratio from the VIN? No build sheet that I know of. If I do have the 3:09 then that means I could possibly get my hands on a 3:45--actually a pair of them. Wonder why Chrysler didn't list anything but 3:09 for all V-8 Hemi equipped 2013 models?
Old Apr 6, 2014 | 08:43 PM
FSTDANGO3's Avatar
FSTDANGO3
Are you signed on in DODGE.COM owners section
If you are go into it and look under the Learn and use tab, there is an equipment tab that list stuff in your build
STEVE
