3rd Gen Durango 2011+ models
Vibration in Steering Wheel
Old Jan 22, 2013 | 02:29 PM
  #31
mmillerao's Avatar
mmillerao
I'm not convinced that the factory Goodyear tires are even round. They suck so bad at first. I had quite a bit of vibration for the first 10k miles. I've kept them rotated at each oil change and now at 15k miles, they actually seem to be much smoother and quieter. Good thing since looking at them at 15k, I bet these tires will last 40k or better which isn't bad.
Old Jan 24, 2013 | 02:15 PM
  #32
skeleton rider's Avatar
skeleton rider
Originally Posted by jlused
Hi everyone,
I recently purchased a 2012 Crew AWD 3.6 V-6 (~850 miles on it thusfar), and I wanted to check with the community if I'm experiencing a totally normal phenomen with my D, or if I have a problem. Here's what I'm experiencing:
When accelerating, at certain RPM, I can feel a very slight vibration from the engine through the steering wheel. The wheel does not visibly shake and the engine generally sounds very smooth, but I can feel just a hint of roughness through the wheel. What I can't tell is whether this is just a hint of roughness in the Pentastar, or if something is wrong. I've also thought at times that I'm feeling a general vibration through the wheel around 40 mph. I initially thought it could be a wheel balance issue, but I do not always feel it, and certainly don't feel it on the highway. How is the steering on your D? Does anyone else feel an ever so slight vibration? I can't tell if I've simply driven vehicles in the past (mostly Hondas and one BMW) that had numb steering and didn't convey any vibration, or if something is off. I could see the Hondas' steering being numb and the BMW simply not having vibration due to the inherent smoothness of the inline 6.
Thanks.
Posted from Dodgeforum.com App for Android
Old Jan 26, 2013 | 11:22 AM
  #33
12HemiR/T's Avatar
12HemiR/T
At approximately 13k, and after 2 trips to the dealer, I took my D to a shop that specializes in road force balance and 4 wheel alignment. From day one I was experiencing vibration at 65-70 MPH and a pull to the left and the steering wheel was off-center. What the shop presented to me pre/post was not surprising.
First, all but 3 wheel/tire assemblies were out of balance anywhere from .25 oz to 1.25 oz. Here are the initial road force measurements: 15 lbs; 17 lbs; 4 lbs; and 2 lbs. The shop match mounted the 2 higher wheel/tire assemblies and reduced the road force to 13 and 7 respectively. All 4 wheel/tire assemblies were then balanced to 0. My D rides on the Kumhos. I discussed the results with the shop owner. He mentioned that I might still feel a vibration in the wheel/tire assembly with 13 lbs, but that was the best outcome.
Second, the alignment that the dealer supposedly performed had front toe readings of L 0.07" R -0.00" for total toe of .007". The rear had toe readings of L -0.03" and R 0.02" for total toe of -.02". The thrust angle was -0.05 degrees. The front toe was adjusted to 0.05" on each side for total toe of 0.10" and the rear toe was adjusted to 0.05" on each side for a total toe of 0.10" and the resulting thrust angle was -0.00 degrees.
While I had to pay for this out of my own pocket, the truck goes down the road straight down the road and the vibration has disappeared. Upon the second visit to the dealer my service advisor explained that the pulling and the vibration was likely caused by the road conditions. Really. I even called the Dodge Customer Care and what I was told was that the dealers are the eyes and ears for Chrysler and offered no additional help. In my opinion the dealers first, don't want to spend the time and second, are ill-equipped to properly to fix these types of issues correctly the first time.
If you are are experiencing similar issues I would go to a reputable (independent) shop that has road force balancing and match mount capabilities and a good alignment technician. The D is now much more enjoyable to drive and I am happy with the outcome. However, I am not happy that I had to spend $200+ and multiple visits to fix the problem. I will take that up with Dodge (again).
Old Jan 26, 2013 | 11:56 AM
  #34
CMil527's Avatar
CMil527
Glad to see u got it corrected unfortunately it seems that the dealerships handle situations like this more often then not which is we none of us have any faith in them.
Old Jan 27, 2013 | 08:13 AM
  #35
JRRF's Avatar
JRRF
No doubt this type of thing takes time and effort to resolve, and frequently the dealer doesn't have the will or the expertises. Regardless, I'd be curious how much of the road force/balancing issues are in the wheels vs. the tires.
Old Jan 27, 2013 | 02:42 PM
  #36
12HemiR/T's Avatar
12HemiR/T
In my case both wheels that were match mounted were within spec and did not have excessive runout in either lateral or radial measurements.
Old Jan 28, 2013 | 08:29 AM
  #37
JRRF's Avatar
JRRF
That's not particularly surprising. Khumo tires are not know for quality construction or a high level of quality control. With your next set of high quality tires you may never have to worry about this issue again.
Old Jan 28, 2013 | 09:38 AM
  #38
12HemiR/T's Avatar
12HemiR/T
Well said. Sadly, over the weekend I started looking for that next set of high quality tires!!
Old Sep 12, 2013 | 10:07 AM
  #39
zimmer54's Avatar
zimmer54
I have same problem on My 2011 D. R/T, Starts at 55-65Mph.
Will try Rotating GoodYears Tires, Were put on in June before I got it.
Balance will be done and I will go from there.
Love My d, has 29,000. Miles, Have had it for two Months.
Old Sep 12, 2013 | 03:18 PM
  #40
zimmer54's Avatar
zimmer54
Had all 4 wheels Bal.( Goodyears) and Rotated on My 2011 D. R/T AWD today, Big improvement, Very smooth ride, Discount Tire here in Phoenix did the work, Great job and Service. D. had steering wheel shake at 55-65Mph, Gone $40. Fix
