3rd Gen Durango 2011+ models
2011 durango radio help?
Old Mar 31, 2012 | 09:24 PM
mikedimike's Avatar
mikedimike
Question 2011 durango radio help?
any one know how to connect an amplified sub on an alpine amplified system the radio i presently have is the 730n premium gps nav. i would like to add an amplified bazooka thank you in advance mike
Old Mar 31, 2012 | 10:49 PM
MJNewman's Avatar
MJNewman
cheapest is hi/lo converter or if you want get the mygig lockpick and it comes with all the wiring needed to hookup system.
Old Apr 1, 2012 | 04:34 AM
mikedimike's Avatar
mikedimike
amy other suggestions?
Old Apr 2, 2012 | 10:20 AM
baum's Avatar
baum
Technically the RCA output of the mygig is for a rear monitor. Can you use if for an amp-yes but its a very low voltage (not getting the best signal to the amp). Easiest way is to snag it after the factory amp using a hi-lo converter like stated above. you need signal somehow to the sub. with your setup you may be able to do it without the hi-lo and just wire your speaker signal to the bazooka.
There are NO other ways.
PS. search the forum there are many discusions on this topic
Old Apr 2, 2012 | 06:11 PM
Stoopalini's Avatar
Stoopalini
PAC makes adapters for different vehicles, to provide low level outputs for amps. A quick search found this, but there may be others as well.
http://pac-audio.com/productDetails....&CategoryID=28
Old Apr 2, 2012 | 07:14 PM
CMil527's Avatar
CMil527
try pac i've used their products before with good results!
Old Apr 3, 2012 | 07:00 AM
baum's Avatar
baum
I agree that pac makes great stuff, but for 150 and that unit makes the bass trebel and mid in-op you will need a good amp with adjustments or someo sort of cross over.
S simple cheat hi-lo works justa as good. or if you want to spend a little money go for the mtx re-q
