3rd Gen Durango 2011+ models
Installation of a fully integrated DVD system
Old Apr 27, 2012 | 01:54 PM
wow's Avatar
wow
I got my money back today - no luck with the dealership getting an OEM system ordered and installed through them. I've only been able to find 2011 systems but without the built-in climate control *****.
Old Jan 12, 2024 | 09:35 AM
Jpverbs's Avatar
Jpverbs
Default Question?
Originally Posted by Scottina11heat
I installed the factory VES in my grand Cherokee. It was pretty easy...but time consuming. I had to drop the headliner and A pillars to run the wiring harness and add the mounting bracket. Not too bad...they are just BSing you since the 11+ systems run off the headunit and the harness just has to be fed to the headunit. I had to run two harnesses...one from the drop down screen to the headunit and then ine from the headunit to the dvd player on the back of the console. The wiring harnesses were less than $150 for two from what I remember.
Was there a place for bracket to mount in celling already there for the screen ? I heard you would have to weld attachment? Also would you have part numbers for all the parts? Also the dvd unit you mentioned, is that the part that lives in the center console?
Old Dec 2, 2025 | 08:05 PM
Jpverbs's Avatar
Jpverbs
Hey do you have all the part numbers for the items to get this to work?
