3rd Gen Durango 2011+ models
2022 Durango Right Rear Ratting Noise
Old Dec 2, 2025 | 11:44 PM
KyleH's Avatar
KyleH
Default 2022 Durango Right Rear Ratting Noise
Hello everyone!
I’ve been dealing with a loud rattling noise coming from the right rear (I think tire area) of my 2022 AWD Durango.
It is VERY inconsistent.. to the point where I am frustrated cause I can’t find exactly when it happens. Always the same frequency though. Starts when I get up to about 10 mph and will randomly go on and off from there. Lately it has been more when I am braking. Is it possible that something within the brake system is loose and rattling?
Things to know: about two weeks ago RR wheel bearing was replaced. Shop did not see any other issues. Differential fluid could require maintenance in future.
Nothing in cup holders or around car moving around. Cleared everything out yet noise still happens.
Hoping someone else has had the same problem and it was an easy fix! One of those things where the noise is annoying and would love a quiet car again.
I provided a video of the sound. It’s a little quiet in it so may have to turn volume up a bit.
Thanks for any help!
Old Dec 3, 2025 | 10:41 AM
Post it to you tube and link it here. People don't like opening attachments.
Old Dec 3, 2025 | 04:37 PM
DodgeCares's Avatar
DodgeCares
Concerns as such are never fun and we understand that in it's entirety. If support is needed, we can definitely look into this for any TSB's or STAR cases for possible answers. Feel free to contact us directly if needed.
Chris,
Dodge Cares
Old Dec 4, 2025 | 02:03 PM
SHO Rod's Avatar
SHO Rod
Was the noise present before or after the wheel bearing was replaced? Can you determine if the noise appears to be inside or outside the cabin? Has someone checked to make sure a parking brake shoe has not delaminated? Have you checked for something moving around in the cubby in the rear floor behind the 3rd row?
I'm at work so I didn't take a look at the video you linked to so I apologize if that would answer a couple of these questions.
-Rod
