3rd Gen Durango 2011+ models
BT Catch Can installed
Old Apr 29, 2012 | 01:29 PM
jdloyd01's Avatar
jdloyd01
Default BT Catch Can installed
Finally got the time to install my BT catch can. It wasn't too bad. The hardest parts were fabricating a bracket and the hose routing.
I made a bracket out of a 12" simple metal stock (in this case I used brass b/c the store was out of stainless and aluminum. I was too lazy to shop around). I got something with some thickness to it to be sure it could hold the weight.
I decided to mount it to the bracket in front of the fuse box. The seemed to be the easiest place for me.
Here are the photos:
Old Apr 29, 2012 | 01:36 PM
MiamiRT's Avatar
MiamiRT
Looks good, but you had to fab your own bracket? They don't provide one?
Old Apr 29, 2012 | 01:47 PM
CMil527's Avatar
CMil527
Looks good!
Old Apr 29, 2012 | 04:02 PM
jdloyd01's Avatar
jdloyd01
Yeah, Billet does not have a bracket for the Durango yet. Not sure why. Maybe its b/c there isn't a ready spot to mount it. I think they may be working with Dodge to come up with something.
Old Apr 29, 2012 | 10:25 PM
Mike D.'s Avatar
Mike D.
Just sent you a PM.
Old May 1, 2012 | 10:52 AM
GoldRangoTX's Avatar
GoldRangoTX
I was able to use the little elbow and extension tube to clear the fuel runner, with trimming the supplied hose from BT.
http://s1054.photobucket.com/albums/...urrent=056.jpg
http://s1054.photobucket.com/albums/...urrent=059.jpg
Here is what you will find after about 2,000 miles:
http://s1054.photobucket.com/albums/...rent=001-1.jpg
Old May 1, 2012 | 11:31 AM
coldsteel's Avatar
coldsteel
And for those of you that don't know...this is totally normal for the HEMI engines; the catch can keeps all that crap out of the intake manifold.
Old May 1, 2012 | 01:21 PM
SINISTERRT's Avatar
SINISTERRT
You can use the 5.7 z-bracket they sell. I did and it mounts in the empty threaded hole on the block by the water pump. I'll post a pic later or you can use the install instructions on their website.
Old May 1, 2012 | 07:02 PM
jdloyd01's Avatar
jdloyd01
Thanks for the tip. I think I mod my design to use the OEM tube like you did.
SINISTERRT: Great find. Thanks for posting that. Is it better to mount the CC to the motor or is it okay to mount it to the fuse box like I did? I was sure to leave enough hose to compensate for the motor torquing.
Old May 1, 2012 | 08:05 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the engineer in me wants to see what the inside of one of these things looks like, anyone got any pictures??
