3rd Gen Durango 2011+ models
vehicle moving on startup?
Old May 11, 2012 | 09:43 AM
DodgeCares's Avatar
DodgeCares
Originally Posted by 5.7HemiSport
2012 RT AWD with pushbutton start: Transmission in park, level garage, park brake off.
Please try this and confirm if you have similar results:
1. Sit in vehicle
2. Foot on Brake
3. Push Start Button (keep foot on Brake)
4. Drivetrain clunk/shudder no movement
1. Sit in Vehicle
2. Foot on Brake
3. Push Start Button (remove foot from brake quickly)
4. Drivetrain clunk/shudder with vehicle rocking forward
It rocks enough that in a parking lot you may look in the mirror expecting to have been bumped by anopther driver backing into you.
I could find no service bulletins regarding this issue. Have you had the dealer look into this for you? If the dealer cannot resolve this issue then anyone who has this problem should call the Chrysler Customer Assistance and have them get a Chrysler tech involved to correct this issue. Numbers below.
800-992-1997 United States
800-465-2001 Canada
Old May 11, 2012 | 10:58 AM
46fever's Avatar
46fever
Originally Posted by BubbaRadioNetwork
My 12 R/T with 1500 miles has no issues
+1 exact same model, miles, and color.
I don't drive it as much as my wife does, but I have never heard any clunk.
Old May 11, 2012 | 11:54 AM
dizney24's Avatar
dizney24
Last time I was at the dealer I asked about this I was told it was normal
Old May 11, 2012 | 02:41 PM
12hemiawdcitidale's Avatar
12hemiawdcitidale
I did notice when I shift the truck from say drive to revers that it clunks into gear, I have a 2012 Citadale with the Hemi. I just assumed that it was part of owning a truck and it has less than 200 miles on it.
Old May 11, 2012 | 08:58 PM
jdloyd01's Avatar
jdloyd01
I have a 2011 AWD R/T I have noticed it move forward or back a bit when I start it (usually using remote start) if I don't have the parking brake set. It not much, just enough to be noticeable. I thought it was related to the hill assist. I'm pretty sure the D has it. Its like the hill assist is "on" when the car is off, when you start it releases.
Someone who knows more about that feature can probably chime in,
Old May 11, 2012 | 09:04 PM
jdloyd01's Avatar
jdloyd01
FYI here is the docs on the hill assist for 2011, standard on all models (via Dodge):
Hill Start Assist allows the driver time to transition from brake to throttle to achieve a smooth launch on a grade. The system will hold brake pressure for about 2 seconds upon the driver's release of the brake pedal. The system decreases wheel pressure in response to increasing throttle to provide a smooth launch.
Old May 12, 2012 | 12:25 AM
12hemiawdcitidale
Hill Start assist works pretty well, but it is for the 2 seconds then the truck start to move backwards, in the SF hills, I do this my instinct by now since I'm use to driving a 5 speed.
I think what is being described here is normal tranny movement but I agree check your tranny fluid.
If you stand behind the truck you while its off you can push the truck a bit, maybe that's just the sticking of the gears with the fluids.
Old May 13, 2012 | 11:05 PM
46fever's Avatar
46fever
I did not think my '12 R/T did it, BUT when paying REALLY close attention:
- with brake on = no noise or movement
- if brake is released immediately after starting = no noise, but slight "lurch"
Old May 13, 2012 | 11:31 PM
safford197's Avatar
safford197
For those of you experiencing this are you parking on a hill / incline? I wonder if you were to set the parking break before shifting to park if the problem wouldn't go away on it's own?
Old May 14, 2012 | 11:18 PM
5.7HemiSport's Avatar
5.7HemiSport
Hi all - sorry I have not been able to get back on. This is my wifes truck so I only get to really drive it on weekends. A couple things to reply from above
1. Parking on flat grade still produces lunge
2. Hill assist is OFF on my control panel
3. Have a follow up with dealer in a couple weeks. Will report back if I get any resolution
4. Still have not checked tranny fluid sorry
