3rd Gen Durango 2011+ models
Mopar steering wheel install how to and pics
Old May 16, 2012 | 10:11 PM
MrSnowflake's Avatar
MrSnowflake
Originally Posted by Scottina11heat
Very easy to do on the 2011+ Durango[/URL] ...
tools needed-----
*trim stick
*20 torx driver
*10mm socket
*10mm torx bit
FIRST---DISCONNECT the negative terminal from the battery using 10mm socket! The battery is located under the passenger seat of the durango/grandcherokee[/url] Gather tools!
2-use trim stick to pry open two small covers on each side of wheel...just to the left and right of the audio controls. Use 10mm socket to remove each bolt. Airbag will pop off.
Remove small black harness from bag. next remove two yellow harnesses from bag. Each harness plug has an orange rectangle on top....use your fingernail to pull those straight OUT. Then use some force to pull plugs straight OUT. Airbag is off!
3-use 10mm Torx bit and remove single torx bolt from center of wheel. Its takes some force to get it started! Remove backing plate from wheel as well. Next pull wheel off and follow directions from Grant printout or just remove 4 20 torx screws on back of wheel and switch parts and spokes over. Its VERY easy and took me 20 minutes to do ALL! Heres the results!
Scott, great post...thanks for the instructions and the sweet pics. This looks absolutely AMAZING!!!
Old May 16, 2012 | 11:55 PM
IndyDurango's Avatar
IndyDurango
As a fan of blue and not red, super thrilled to see the all blue trim setup.
I know you did it manually, nevertheless, huge kudos to a job exceptionally done.
Dodge should ship a blue option with the seat, console, shifter and steering wheel setup... and then send you a royalty on each sale!
IndyDurango
Old May 17, 2012 | 04:23 PM
stevewhiteparts's Avatar
stevewhiteparts
looks awesome!!!!!!!!!!!!!!!!
Luke
Old Jan 30, 2013 | 09:43 PM
SS2RT's Avatar
SS2RT
nice write up thanks...enticed me enuff to order the
red trimmed 'wheel...almost went blue and match it up with
the blue and chrome mopar shifter, but just too much red
to contend with already inside that im not looking to
change, so red it is...
Old Jan 30, 2013 | 10:26 PM
CMil527's Avatar
CMil527
Nice... Your gonna love it, I love mine with the red stitched **** as well!
Old Jan 31, 2013 | 08:17 AM
mac424's Avatar
mac424
Ok, I missed the link where to get this said wheel... It looks freaking great!
Old Feb 5, 2013 | 09:23 AM
Scottina11heat's Avatar
Scottina11heat
its on ebay
Old Feb 5, 2013 | 06:23 PM
CMil527's Avatar
CMil527
Stevewhiteparts offers them.
