3rd Gen Durango 2011+ models
amp install
Old Jun 4, 2012 | 02:15 PM
wcrstereo's Avatar
wcrstereo
Default amp install
looking to install a aftermarket amp in the near future , Only question is what is
everyone using for the remote wire and location. any pictures you have would be great
Old Jun 4, 2012 | 09:00 PM
Double D Mods's Avatar
Double D Mods
Former Vendor
http://www.pac-audio.com/productDeta...&CategoryID=28
Old Jun 5, 2012 | 06:48 AM
baum's Avatar
baum
i grabbed mine at the flashlight in the rear left. I used this signal to trigger a relay so it doesnt put any current draw on the vehicles circuit.
That harness is way is not necessary. a simple hi-low converter is all you need.
Old Jun 5, 2012 | 08:46 PM
wcrstereo's Avatar
wcrstereo
i was going to use a converter but Im just going to add a pioneer 4400bh headunit instead
Old Jun 6, 2012 | 10:43 AM
SINISTERRT's Avatar
SINISTERRT
I added a fused to a switched power source in the factory fuse box. I believe it was the radio fuse
Old Jun 6, 2012 | 04:48 PM
Ryan Albert's Avatar
Ryan Albert
With this hu will you be able to keep your steering wheel controls for music and Bluetooth? Will the iPod hookup in the center console still work?
Old Jun 7, 2012 | 07:20 AM
Double D Mods
Former Vendor
SW controls
YEs as long as you add a pac audio swi-rc or Metra ASWC
I would only use the Metra ASWC on a Pioneer. Kenwood you still need to program them
BT will need to add the aftermarket MIC that comes with the radio
No on the ipod mount in console.
Kenwood has a harness coming late this year that will allow us all to change the radio and retain all stock features.
Old Jun 7, 2012 | 08:37 AM
wcrstereo's Avatar
wcrstereo
its has the usb and ipod connection that I will install in the center console
Old Jun 7, 2012 | 08:48 AM
Ryan Albert
Thanks
Old Jun 7, 2012 | 09:00 PM
Ryan Albert
I installed an amp today and used the "power antenna" wire according to the Jeep forum think it was grey and orange. I almost think the amp fires when I open the door and my "dash info center" lights up. I'll keep an eye on it and may end up changing it. Otherwise install was pretty easy Installed the amp under the pass front seat. If you do that just make sure to leave enough slack in the cables to remove the door to access the battery. I used a loca25 to hookup to the Factory stereo and a PAC lc1 to control the bass.
