Found out how to color match the reader lights for the rear two rows and front readers. What i could use info on is how to drop down the front section that has the sunglasses holder and homelink stuff so that i can get access to the circuit board. If anyone has info that would greatly help so i don't damage that top console
Any luck on this yet?
Has anyone out there purchased and installed the interior LED kit from ebay?
Haha yes there is an update. It is possible to match the readers to the regular dome part you have to pop out the whole assembly then there are two small screws holding on a circuit board. Take those out and then you flip it over and the LED is exposed. Now the hard part. Its either a 5050 Surface mount led. Or just barely Im talking barely smaller. With six solder points total three on each side. You'll need a solder gun, solder sucker and midget hands. I didn't successfully get it done so i never updated. They make a special solder tip that is a solder sucker, component holder that does it all in one move. And FYI if you attempt if it fails and you ruin the solder joints the part is 115.00 dollars + tax. I learned the hard way
Did you use the 5502 on the fogs or the 5202? Also, how easy was it to remove the fogs? What wattage?
It should be the one on the right i believe it is the 5202 style and i got the brightest wattage 12w. Also has no error codes. Don't know if dodge even monitors bulb out on the D.
