3rd Gen Durango 2011+ models
Identification Needed - Relay Box
Old Jul 9, 2012 | 03:09 PM
Total Loss's Avatar
Total Loss
Default Identification Needed - Relay Box
Out of curiosity, does anyone know where I can get a breakdown of this relay box? I've looked online and in the owner's manual, but I haven't been able to find anything. This relay box sits under the hood, directly behind the main fuse box on the passenger's side. As you can see, the box holds a maximum of five relays and three are installed. This is on a 2012 Durango Citadel with the 5.7L engine, if that makes a difference.
Thanks in advance for your help!
Old Jul 10, 2012 | 10:40 PM
Total Loss's Avatar
Total Loss
C'mon fellas! Someone here has the answer to this, right?
Old Jul 10, 2012 | 10:43 PM
CMil527's Avatar
CMil527
PM forum member Dodgecares i'm sure he has to have access to this info!!
Old Jul 10, 2012 | 10:46 PM
Total Loss's Avatar
Total Loss
Thanks for the heads-up! Doing this now...
Old Jul 10, 2012 | 11:16 PM
Scottina11heat's Avatar
Scottina11heat
try wk2jeeps.com
Old Jul 11, 2012 | 09:26 AM
DodgeCares's Avatar
DodgeCares
Total,
I sent you a PM requesting some additional info.
Old Sep 18, 2012 | 01:32 PM
Total Loss's Avatar
Total Loss
Originally Posted by DodgeCares
Total,
Chris,
I was wondering if you've ever heard anything back on this. If so, please let me know.
Thanks!
Old Sep 18, 2012 | 10:49 PM
kingofwylietx's Avatar
kingofwylietx
Did you look under the cover you removed to see it? Many times, it is molded into the plastic cover. Let us know if it is there.
Old Sep 18, 2012 | 11:02 PM
Total Loss's Avatar
Total Loss
There's not a diagram of any kind molded or stuck to the interior or exterior of the lid. It would've been nice if it was there, though.
Old Sep 19, 2012 | 06:23 AM
coldsteel's Avatar
coldsteel
Don't have specifics, but the 'missing' relays would be present if you had a Canadian/export model with DRLs.
Our US-spec Durangos do not have the correct harness underneath that box to allow DRLs to be activated. You could 'plug' relays in the box, but they wouldn't connect to anything.
I suspect the other two relays control the headlamps/foglamps in some fashion, but no one has been able to locate a service manual or schematic describing that box.
