Oil Change DIY
I'm not suggesting these guys aren't legit, just that the value of their services is limited. Even new oil has "junk" in it. And you'll have all kinds of other signs there's something wrong with your engine that obviate the need to spend money analyzing your oil. It's basically worthless short of your doing some kind of "experiment".
Don't get me started on "experiments". I think your using the word " limited" a little to lightly. An example of the value of analyzing you oil? I built a camaro a fees years back with my buddy and upon receiving our oil review we discovered elevated levels of coolant in the oil. The amount was very low and the oil did not show any signs of contamination I.e milky, separated or foamy. We decided to pull the heads and low and behold we had a split in the head gasket. $25 for the gasket and 35$ for the test. That motor has 70k more miles on it today. That motor had a ton of track duty and we would most likely have spun the bearings or blown it up. That was very Valuable info.
That is also a completely different situation from a factory built vehicle with a 100K mile warranty on the powertrain. They don't warrant it for that long unless they are pretty certain you're not going to have the types of problems you might experience with a hand built motor that is also doing duty at track speeds. You basically had an experiment on your hands, and so it was
valuable to continue to test for potential problems under those conditions. But for a factory vehicle that goes back and forth to the grocery store, and pulls the trailer a few
times a year, it's of limited value other than to satisfy your curiosity.
That is also a completely different situation from a factory built vehicle with a 100K mile warranty on the powertrain. They don't warrant it for that long unless they are pretty certain you're not going to have the types of problems you might experience with a hand built motor that is also doing duty at track speeds. You basically had an experiment on your hands, and so it was valuable to continue to test for potential problems under those conditions. But for a factory vehicle that goes back and forth to the grocery store, and pulls the trailer a few times a year, it's of limited value other than to satisfy your curiosity.
Also the manufacturers set oil change intervals for normal and severe service. Severe service OCI is usually half that of normal. So how do you know for sure where you fall on the scale?
Many UOAs on bitog.com have shown the oil on its last breath when following the OLM.
Funny how so many take oil seriously and argue it to the point of no return, then go and buy 22's or 24's and don't upgrade their braking system. lol
Truck can't stop as fast and may have issues under a panic stop but hey, my oil is clean! hahahahahaha
At the end of the day do what makes you sleep better at night and use whatever oil you want. It's your truck to deal with, nobody else's.
I don't agree. First of all let's use 60k for a powertrain warranty since most manufacturers offer that. So the engine only has to last for 60k miles; after that, they couldn't care less. What if you plan to keep the car for 150k plus miles? You could have trouble down the road because you followed the car's OLM to the letter.
I hate oil threads, always an argument no matter what forum.
I thought just about everyone (including Kia) offers a 100K powertrain warranty now. They do so because engines -- with regular oil and normally scheduled oil changes -- will easily last that long. They don't put that warranty on engines unless they are VERY sure the engine will last beyond that, not that it will JUST make it.
But Ford, Toyota, Honda, VW, Mazda, BMW, Audi, Mercedes, Scion, Subaru and others are all 60k or less.
http://www.cars.com/go/advice/Story....ry=manWarranty
Plus some engines (e.g. Honda V6's?) are supposedly "known sludgers" when following the recommended OCI.
I guess more than I realized... Didn't realize GM was now up to 100k.
