3rd Gen Durango 2011+ models
The dreaded rear end clunk noise went away!
Old Nov 17, 2012 | 03:02 PM
DJ Hellfire's Avatar
DJ Hellfire
Wink The dreaded rear end clunk noise went away!
So, everyone (it seems) with the rear load leveling suspension experiences the clunk noise in the rear over bumps. I had this issue on my truck too, but it never bothered me as much as it seems to bother other people because I usually have the music pumping anyway. But I also just realized that the noise has gone away in my truck. Got about 4400 miles now and the suspension is quiet. It actually went away a while ago, but just forgot to post about it. So it must be something that just has to break-in.
Old Nov 17, 2012 | 09:22 PM
kingofwylietx's Avatar
kingofwylietx
My break-in must be taking longer than yours. I have about 32k miles and I have the noise.
Old Nov 17, 2012 | 10:03 PM
12HemiR/T's Avatar
12HemiR/T
Nope. 10.2k and occasionally still hear clunk.
Old Nov 18, 2012 | 02:41 PM
diggy33's Avatar
diggy33
I stopped noticing mine at about 12k; got little over 20k on it now and havent noticed it since.
Old Nov 23, 2012 | 05:37 PM
CMil527's Avatar
CMil527
ohhh boy
Old Nov 23, 2012 | 08:44 PM
rangort11's Avatar
rangort11
On my '11 R/T dealer change the driver's rear shock. After that all quite
Old Nov 29, 2012 | 11:26 PM
adbutz's Avatar
adbutz
Check your tire pressure. I noticed mine decreased when I let air out of my tires. Still have it to a degree but its much more tolerable. My tire pressure was around 42psi in each tire when I got this vehicle. I reduced the pressure to 36 psi as recommended on the door and the sound decreased. Now that is -15 degrees Celsius the pressure likely reduced some more as I don't hear the sound unless I hit a good sized bump or joint in the road
