3rd Gen Durango 2011+ models
Mopar Pedal Cover Install
Old Mar 1, 2013 | 07:35 PM
  #31
MG2012CREW's Avatar
MG2012CREW
Smile pedals
Just ordered a set, hope i don't break any fingers. Will try the head gun tactic.
Old Mar 1, 2013 | 09:30 PM
  #32
FSTDANGO3's Avatar
FSTDANGO3
Careful with the heat gun
Old Mar 1, 2013 | 09:32 PM
  #33
FSTDANGO3's Avatar
FSTDANGO3
Originally Posted by CMil527
Ahhh...keep us posted how that fits!
From what I gathered its not bad I read to use a piece of 3m double sided tape under it to keep it more snug
STEVE
Old Mar 1, 2013 | 11:47 PM
  #34
CMil527's Avatar
CMil527
STEVE
Gotcha... keep me posted, I need to grab one!
Old Mar 2, 2013 | 03:10 PM
  #35
MG2012CREW's Avatar
MG2012CREW
Talking
Will a hair blower work. Lol
Old Mar 3, 2013 | 08:17 AM
  #36
FSTDANGO3's Avatar
FSTDANGO3
maybe depending on how arm it gets the rubber. Or I read a bucket of real hot water, sit it in water for a while and it becomes real flexible
STEVE
Old Mar 4, 2013 | 08:42 PM
  #37
FSTDANGO3's Avatar
FSTDANGO3
Ok got the E brake pedal installed. The pedal is the correct dimensions but curved on the wrong side. So I modded it, I gently removed the curve from it by using a wooden dowl and small hammer. I then modded the rubber slightly on the back of the pedal to allow it to slide over the durango's pedal surface. I then mixed up some 2 part epoxy and applied it to the rear of the pedal pad. After letting it tack up a bit I reinstalled the pedal pad and lined it up. I used a spring loaded clamp to apply pressure to the pad and metal arm evenly to allow the epoxy to cure completely without chance of movement.
After a few hrs I checked the pad and it is set up well. I reapplied the clamp for the remainder of the day today and will remove it tomorrow. Its should work well.
STEVE
Old Mar 4, 2013 | 09:43 PM
  #38
MG2012CREW's Avatar
MG2012CREW
STEVE
Nice job, looks great.
Old Mar 4, 2013 | 10:01 PM
  #39
CMil527's Avatar
CMil527
STEVE
Nice job bro... matches nicely, now its time to do mine!!
Old Mar 4, 2013 | 11:27 PM
  #40
bluebastion's Avatar
bluebastion
STEVE
Very nice! I think someone else had one custom made... anyone have the thread saved?
