3rd Gen Durango 2011+ models
tail light removal?
Old Jan 28, 2013 | 06:06 PM
baum's Avatar
baum
Default tail light removal?
just a quick question... how does the tail light in the rear hatch door come out? i removed the 2 nuts and it seems like there are hidden screws.
Thanks
Old Jan 28, 2013 | 06:57 PM
coldsteel's Avatar
coldsteel
You won't like this answer, but you have to loosen the interior panel to best access the other 2 plastic nuts which are under that panel.
If you are trying to remove the unit from the hatch then you might as well remove the whole interior panel because you have to remove the rear applique (the DODGE trim under the window) which traps the inboard light units underneath and prevents them from just pulling off when the 4 plastic nuts are removed.
