3rd Gen Durango 2011+ models
Brake Vacuum Leak?
Old Feb 12, 2013 | 08:57 PM
D3-Blk-Hemi's Avatar
D3-Blk-Hemi
Default Brake Vacuum Leak?
I think I'm having a brake vacuum leak with the D @ 4700 miles. When the vehicle sits overnight I get a heavy pedal feel before starting her. Then after start up the pedal feel returns to normal. Any thoughts as to what the failure is the vacuum booster pump, check valve or etc...?
Old Feb 13, 2013 | 02:08 AM
Didhefocus's Avatar
Didhefocus
There's no vacuum without the engine running.
Seems normal to me!
Old Feb 13, 2013 | 08:03 AM
coldsteel's Avatar
coldsteel
Seems normal to me!
That's not true. When the engine is running, it creates vacuum and as long as your foot is off the brake when you shut the engine off, there should be residual vacuum pressure.
When I start my D after it has been sitting overnight, there is no change in the pedal feel on that first 'depress brake to start' than when the vehicle is running.
D3, you may have an issue.
Old Feb 13, 2013 | 08:52 AM
D3-Blk-Hemi
Thank you, any idea what the issue may be? Anyone else having this issue?
Old Feb 13, 2013 | 10:06 AM
Didhefocus's Avatar
Didhefocus
Every vehicle I've ever owned (with power brakes) has had a different feel on on the brake pedal without the engine running.
Unless you're have real braking issues why are you concerned about this?
Old Feb 13, 2013 | 10:46 AM
D3-Blk-Hemi
Because there is a vacuum leak! And Leaks get bigger! How is this not a real problem? I like my vacuum power assisted brakes on a 5,200 lbs vehicle or better yet while towing a 3,500 lbs trailer with my family in the car traveling at 65 on the highway and having no brakes or limited braking ability!
The pedal feel changed early this week and is distinct and causing issues with the vehicle starting function. When I first get in the D in the morning the pedal is extremely firm and I have to press hard to de-activated the lockout function to start the engine. Once started the pedal drops to it's normal position. No other abnormal behavior is found or logged after. From my understanding of a vehicle braking system the vacuum should not bleed out of the system while the vehicle is off. Yes you can bleed the vacuum by pumping the brakes a few times and the same firm pedal feel can be created.
Old Feb 13, 2013 | 02:25 PM
coldsteel's Avatar
coldsteel
I'm thinking Didhe... is missing the fact that it was fine all along and this change just happened.
Off to the dealer, assuming it's under warranty.
Old Feb 13, 2013 | 02:51 PM
CMil527's Avatar
CMil527
Straight to the dealer bro... Any questions about potential brake issues should be addressed asap!
Old Feb 13, 2013 | 03:31 PM
D3-Blk-Hemi
Already made an appointment. Just looking for facts so I have some knowledge of the issue or possible TSB / Recall.
Old Feb 13, 2013 | 07:59 PM
D3-Blk-Hemi
Looks like 2 other similar complaints have been filled with the NHTSA.
http://www-odi.nhtsa.dot.gov/owners/SearchVehicles
