Let's get a mini meet set up!
#91
Finny, use a blow dryer on high heat, heat them up and they will peel right off. then use your finger to remove the rest of the black double sided tape and some goof off to clean up the rest of the sticky on the paint. I have done it on several vehicles that way and always works like a charm! ( no pun intended- as in lucky charm ) HA just beware if you heat them to much they will bend and distort and can never be used again it you want to add them back later.
#92
You can use fishing line as well
I removed all my emblems, prepped them and painted them Black then reinstalled them a slightly different than factory location.
I was able to remove them and even save the factory double sided tape by using a technique of gently prying them with plastic dash tools and heat. They cam right off left no residue and went right back on securely.
STEVE
STEVE
#93
STEVE
STEVE
![Icon Couch](https://dodgeforum.com/forum/images/smilies/icon_couch.gif)
