3rd Gen Durango 2011+ models
Mds
Old Apr 5, 2013 | 03:56 PM
cpeters194's Avatar
cpeters194
Default Mds
Just bought a 2013 Durango and have seen references that when the MDS is activated, the EVIC should indicate that is. Haven't seen it yet and do a lot of hwy miles so figure I should by now...Thx
Old Apr 6, 2013 | 09:07 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill put this in 3rd gen for you
Old Apr 6, 2013 | 10:43 AM
12HemiR/T's Avatar
12HemiR/T
I usually drive using the Fuel Economy display and when the MDS engages you should see a little box displayed as "ECO" in the upper left. Make sure you are not in low range assuming you are driving an AWD or that you are not in "Tow/Haul" mode assuming you have a towing package.
Old Apr 6, 2013 | 11:27 AM
Waynead's Avatar
Waynead
There is a setting to turn that feature on in System Setup. . Just select Display ECO Mode so there is a check mark next to it.
Old Apr 7, 2013 | 02:02 PM
cpeters194's Avatar
cpeters194
Thank you.. Turned the feature on and seeing the ECO now. And sorry about not posting correctly...
