3rd Gen Durango 2011+ models
Sound issues with AM/FM/SAT
Old Jun 28, 2013 | 11:51 AM
insureobx's Avatar
insureobx
Default Sound issues with AM/FM/SAT
I'm having an issue where my stereo will not produce any sound. It picks up channels in AM/FM/SAT but when I turn the volume **** it doesn't show the meter for increasing / decreasing the volume. Anyone had that issue before?
It's the Nav system with the 40GB Hard Drive. When I go to the menu screen, the Audio Settings is greyed out, will not let me press that button.
THought I'd ask here before I called the dealership. Figured I'd have better luck here.
Old Jun 28, 2013 | 01:48 PM
insureobx's Avatar
insureobx
Ok, odd. Went to the truck at lunch and the sound works. I had turned it off twice to see if it would work while I was on the road and it didn't make a difference.
Guess I'll let it ride until I have to do something with it.
Old Jun 28, 2013 | 02:09 PM
JRRF's Avatar
JRRF
There are different modes. When the radio system goes into telephone mode, the volume adjustment is only for the bluetooth telephone for instance. Also, if you get a signal for your acc shutting off, it will mute the audio. Don't know if this has any relevance for your problem, but wanted you to have the info just the same.
Old Jun 28, 2013 | 03:24 PM
insureobx's Avatar
insureobx
Thanks JRRF. It did happen after I unplugged my iphone from the radio. I turned off the bluetooth on the phone and that didn't seem to make a difference. Maybe just a hiccup with the phone being unplugged from the radio.
Thanks !
Old Jun 29, 2013 | 08:20 AM
JRRF's Avatar
JRRF
Yeah, it may not have "released" the iphone, but that would still be a problem that the dealer will need to look at.
