3rd Gen Durango 2011+ models
Clearcoat scratch/scuff repair
Old Jul 13, 2013 | 12:00 PM
SS2RT's Avatar
SS2RT
Default Clearcoat scratch/scuff repair
How hard, how good a chance of success and not just more damage?
Due to someones incompetence (lol) My DD was victim to a plastic garbage can accident, and She has a few light scratches, seems to be surface only, like just the clear.
Was basically just a "rub" or scuff not a big impact or hit
If I run my fingernail over it I can feel the line but its super thin and you can see its just clear that was damaged not really the black paint itself
Anyone have a safe, easy, repair method or product(s) that def work?
I havent tried any rubbing, compounds, or anything yet..
Want a good plan of attack...
Old Jul 13, 2013 | 08:25 PM
FrankADavisJr's Avatar
FrankADavisJr
I am a detailing fanatic and have religiously detailed my vehicles weekly since the time that I used to do it for money in order to save for college when I was in high school. I've tried every product under the sun (Griots, Meguiars, Mothers, Zymol, Zaino, Chemical Guys, etc. etc. etc.)
This evening, I just noticed a scratch in my wife's Moro Blue Metallic Audi A4. A product I really like now is Chemical Guys All In One. But Griots All in One or Zaino All in One would also work. The key is they all have fine abrasives that get smaller and smaller the more you rub, plus a glaze to fill the scratches and diminish their visible impact of the scratch(es).
I would go here: http://www.chemicalguys.com/Chemical...gap_106_16.htm and order it up. I use a microfiber towel with firm finger pressure and both parallel and circular motion. Unless you dug down through the base coat into the primer (a different story altogether - you need to fill and wet sand) then I would start with a glaze/polish like CG AIO.
Good luck!
Frank
Old Jul 14, 2013 | 11:40 AM
Scottina11heat's Avatar
Scottina11heat
something u can try first that can be bought at most auto parts stores...walmart etc. is meguiers scratch X. Youll just need a microfiber towel and some elbow grease.
If that doesn't work....I really like the meguiers m105/205 combo with a DA buffer like a porter cable. But it sounds like the scratch x may work for u.
Old Jul 14, 2013 | 02:50 PM
CMil527's Avatar
CMil527
I've had success with scratchx in the past as well...good luck!
Old Jul 15, 2013 | 09:06 PM
inyadreems's Avatar
inyadreems
If you can't fix it or don't want to go at it alone. Stop by one day and we will work on it together.
Old Jul 16, 2013 | 08:55 AM
IlliniJeeper's Avatar
IlliniJeeper
Meguier's ScratchX has never let me down. Just this past weekend it made quick work of a few paint scuffs on my Wrangler from a flourescent light that fell over onto it. Just took a little bit of elbow grease and all the scuffs are gone. There were a couple of small dings, but, hey, it's a 15 year old Wrangler, I'm OK with a few battle scars.
Old Jul 21, 2013 | 02:16 PM
GizmoDurango's Avatar
GizmoDurango
Thanks for the tip guys. I think I'll pick up some scratch x from walmart too. I have a few light scratches from the past year to get rid of.
Old Jul 22, 2013 | 09:31 AM
inyadreems's Avatar
inyadreems
Make sure to wash, then clay the area before using scratch x, use foam to apply and MF to remove. You might need to hit the area with some polish after scratch x, then top with a sealant or wax.
