3rd Gen Durango 2011+ models
430 Radio Question
Old Aug 15, 2013 | 09:40 AM
moparman72's Avatar
moparman72
Default 430 Radio Question
When I traded my Ram in I pulled out the 430 Mygig non-nav highspeed bus radio that I had put in. Since I have the base radio in my D I was wondering if it will work in the D. Any help would be great. Thanks.
Old Aug 15, 2013 | 11:54 AM
JRRF's Avatar
JRRF
You can get a D with a 430, so technically it could work. Issue might be whether your rig has the necessary wiring and controls connections since it came with the base radio.
Old Aug 15, 2013 | 01:44 PM
Scottina11heat's Avatar
Scottina11heat
it will be plug and play...except for the uconnect phone and voice recognition. Do you have that now?
Old Aug 15, 2013 | 02:32 PM
moparman72's Avatar
moparman72
I do have the UConnect now. Glad to hear it will be plug and play. I hate the base radio.
Old Aug 15, 2013 | 05:06 PM
Scottina11heat
uconnect rearview mirror? What about SXM satellite radio? You may have the transfer the subscription for that.
Old Aug 15, 2013 | 05:07 PM
Scottina11heat
also...take note of the colors of your 430. Will they be the same as in the Ram? I believe the Durango uses blue leds. Does the Ram as well. If not...your lighting may be a different color.
Old Aug 16, 2013 | 08:03 AM
moparman72's Avatar
moparman72
I have the uconnect rearview mirror already. I figuredthe colors would be different but worth it for the features you get with it. They won't move the free trial over to the new radio but I keep getting letters for only $25 for 6 months so I will probably just do that.
Old Aug 16, 2013 | 07:45 PM
Scottina11heat
you should be plug and play then. Go to your local dealer and have the 430 sales code addded to your DD and youll be good to go. Everything will function after that is done.
Old Aug 16, 2013 | 09:09 PM
moparman72's Avatar
moparman72
Thanks. Will the dealer have to add it? When I switched them in the Ram I didn't have to do anything.
Old Aug 17, 2013 | 03:14 AM
Scottina11heat
they dont have to...but you may lose some functionality. I added the 730n to my 11 durango and had the sales code added and everything worked perfect.
