3rd Gen Durango 2011+ models
Need advice on 22's
Old Oct 2, 2013 | 12:41 PM
Gqjeff's Avatar
Gqjeff
hmmmmmm not a big fan of poke.. So maybe the SRT8 wheels r the way to go. I luv the looks of the others better have large dish on them. Love some deep dish wheels. Wonder if they would have much poke with 265 or 275's?
Old Oct 2, 2013 | 12:55 PM
FSTDANGO3's Avatar
FSTDANGO3
OK HERE YOU GO
STOCK SIZE TIRES 265/50/20= 30.81" tall x 10.81" wide tire
265/40/22= 30.64"tall tire X 10.81" wide tire (ALMOST SAME EXACT AS STOCK less than 1/4" shorter these wont stick out at all on a 30 offset rim!!!
275/40/22= 30.97"tall tire X 11.63" wide THESE WILL STICK OUT a 1/2-3/4" on a 30 offset rim
285/40/22=31.304" tall X 11.63" wide THESE WILL STICK OUT a 1/2-3/4" on a 30 offset rim
STEVE
Old Oct 2, 2013 | 01:02 PM
Gqjeff's Avatar
Gqjeff
so 265 on 9.5" wide will sit flush according to the info?
thanks
Old Oct 2, 2013 | 01:18 PM
FSTDANGO3's Avatar
FSTDANGO3
a 35 backspace wheel would be better but 5mm is nothing .20" so less than a 1/4"
The added 3/4" or so of width of the 275 and 285 is what kills you if you dont want them sticking out.
STEVE
Old Oct 2, 2013 | 01:38 PM
Gqjeff's Avatar
Gqjeff
Ok so with the 265 it will still sit flush with fender and not a lot of poke? That's all I am concerned with.. Thanks so much for your time.
Jeff
Old Oct 2, 2013 | 01:58 PM
CMil527's Avatar
CMil527
I did some research as well before purchasing... 275/40-22 Nitto NT-420S - 30.67'' OD & Overall width 10.71'' ... choose your tire then choose your size... good luck!
Old Oct 2, 2013 | 02:00 PM
CMil527's Avatar
CMil527
Also you really shouldn't be too concerned with poke on something this wide and tall it's not like your going to be running a 11'' or 12'' wide wheel. Unless you choose to go with a 225/35 lol!!
Old Oct 2, 2013 | 02:17 PM
FSTDANGO3's Avatar
FSTDANGO3
The formula for calculating tire actual size from Michelin
First number/24.5=WIDTH ACROSS TREAD So 275/24.5= 11.22" wide
Take that number X the aspect ratio: 11.22 X .40=4.49
That is sidewall height so 4.49 X 2 + Rim diameter = rolling height
4.49 X 2 = 8.98 + 22 = 30.98"
so 11.22 wide X 30.98 high
Take a pic straight on CMIL of you dropping a string straight down from fender to touch tread, you tires are out just a bit
STEVE
Old Oct 2, 2013 | 02:24 PM
MJNewman's Avatar
MJNewman
I have 285s and they tuck perfectly when I lower truck down.
Old Oct 2, 2013 | 02:44 PM
FSTDANGO3's Avatar
FSTDANGO3
That would be correct because as the suspension compresses the top of the tire goes in.
And what are the specs on your rims?
STEVE
