3rd Gen Durango 2011+ models
Oil Smells Like 2-cycle Mix
Old Oct 10, 2013 | 12:14 PM
codykeith's Avatar
codykeith
Default Oil Smells Like 2-cycle Mix
My oil smells like it has gas in it. First time I went to the dealership, they said it was because I needed an oil change. Been 500 miles since oil change and the smell is even greater than before. Never had a car smell like 2 cycle mix. D is back in the shop, but mostly because it's still leaking coolant all over the place. I think my D has been in the shop at least 4 days a month since I bought it. The worst part is that they can't give me a rental that can tow. Reliability is not something I would sell someone on with a Dodge.
Old Oct 10, 2013 | 12:52 PM
fishandgrits's Avatar
fishandgrits
I hate to break it to you but many people out there have a simliar reliability issue that drive a Ford, Chevy, Porche, Honda, Cadillac, Toyota, Nissan, etc. so please, let's not isolate it to Dodge. lol
That does not in any way excuse the situation you are in. I hope you get it fixed!
Old Oct 11, 2013 | 09:28 AM
IlliniJeeper's Avatar
IlliniJeeper
Sounds like you have a compression problem. Bad ring or even a pinhole burned through a piston. That'll dump gas into the oil all day long. Hope you're still under warranty because this will probably be a fun repair.
Old Oct 15, 2013 | 01:54 AM
codykeith's Avatar
codykeith
The tested compression, and said it was 180 across all cylinders...
Old Oct 15, 2013 | 07:12 AM
pjw1967's Avatar
pjw1967
Get a sample and have it tested. If you Google "oil sample testing" a number of companies pop up.
Old Oct 15, 2013 | 06:16 PM
codykeith's Avatar
codykeith
Awesome. Just ordered a test kit. Will update with results.
