3rd Gen Durango 2011+ models
2012 tail light flasher
Old Oct 27, 2013 | 06:13 PM
hwy101's Avatar
hwy101
Default 2012 tail light flasher
does any one know where the tail light flasher is located on durango wanted to install led brake light bulbs and wanted to fix the hyper flash with the led flasher
Old Oct 28, 2013 | 10:59 AM
NUTTS12CREW's Avatar
NUTTS12CREW
You will probably have to put load resisters in as well. I have LED's in my outer tail lights, and I have the lamp out message for each side, and the hyper flash as well. I am putting them back to regular bulbs and leaving the LED's in the tailgate. Unless someone knows of a replacement LED for the outer tails with no issues.
Old Oct 28, 2013 | 07:38 PM
coldsteel's Avatar
coldsteel
There are no flashers any more; everything is controlled and monitored by the computers.
It is possible to have LEDs without Hyperflash, but you must place a resistor across the brake/turn wire; the computer monitors the return voltage and if too many volts return (or none) the computer 'thinks' a bulb is out and gives you the warning and hyperflash.
Keep in mind that this A: requires tapping into your brake light wiring (so if you're not comfortable you may want to skip this one) B: you will not be notified if one of your LEDs fails, the computer will always think it's working and C: careful where you mount a load resistor as by their very nature they heat up.
Old Oct 28, 2013 | 09:23 PM
hwy101's Avatar
hwy101
Thanks for all the info ,wanted to see how the 2014 durango tail lights will work they have led turn and brake light. When they are available
Old Oct 29, 2013 | 08:30 AM
hairless_ape's Avatar
hairless_ape
Which ones did use/where did you get them? I'm planning on switching mine over before I tint my tails. I've got no problem installing resistors to stop hyperflash.
Old Oct 29, 2013 | 05:33 PM
coldsteel's Avatar
coldsteel
Got my bulbs and resistors from v-leds.com
