3rd Gen Durango 2011+ models
tow hitch wiring
Old Nov 13, 2013 | 11:51 PM
CPW1265's Avatar
CPW1265
Default tow hitch wiring
Does anyone know if the 14 Durango's are pre wired with the tow wiring harness? Dealer said that even if it doesn't have the hitch from the factory it is pre wired and just need to install the hitch and your good. Can anyone confirm or deny this claim? I want to install it and looking to see how much I'll be spending. My sticker window doesn't mention anything about it. Thanks
Old Nov 14, 2013 | 01:36 AM
MIKEon22s's Avatar
MIKEon22s
still need the dealer to activate the harness in the computer
Old Nov 14, 2013 | 10:26 AM
Crew Member's Avatar
Crew Member
My 13 Crew built last March is prewired.
Old Nov 11, 2014 | 08:36 PM
NY-Durango's Avatar
NY-Durango
Have 2011 Crew Lux V6. If it is pre-wired for hitch where would the harness be located. I took a quick look and did not see it, any suggestions would be appreciated.
Old Nov 11, 2014 | 08:53 PM
FSTDANGO3's Avatar
FSTDANGO3
Up above the spare tire strapped up under there
STEVE
Old Nov 11, 2014 | 09:01 PM
NY-Durango's Avatar
NY-Durango
I checked above the spare no harness. I'm guessing they did not wire the early 2011 models then. Thanks
Old Nov 11, 2014 | 09:25 PM
FSTDANGO3's Avatar
FSTDANGO3
maybe not
Old Nov 12, 2014 | 08:21 PM
MIKEon22s's Avatar
MIKEon22s
Mine was zip tied up by the spare tire I'd say within 10" of where it would be attached to the hitch flange. If its the same PN as a 2013 i have a the oem harness never out of the bag I'll let it go cheap, 50% of retail . I just used the plug on the end once i realized mine had the harness. You can just buy the plug from Dodge or any autoparts store as it is the same 7/4 used on ford/ chevy $
Old Nov 13, 2014 | 08:55 PM
jnschnit's Avatar
jnschnit
My 20111 Crew was not pre-wired, I had to buy the harness and install it.
Old Nov 13, 2014 | 11:15 PM
NY-Durango's Avatar
NY-Durango
How hard is it to install the oem wiring harness and is it basically just run and plug into pre-existing jacks or do you have to splice wires. Any advice would be appreciated.
