3rd Gen Durango 2011+ models
Tire pressure monitoring
Old Dec 19, 2013 | 02:58 AM
LCF's Avatar
LCF
Default Tire pressure monitoring
Dear friends, by the avatars of yours, i see that most of you have replaced the OEM rims. So have i.
And here is my question: after i have replaced my rims and installed 22's with 285/45/22 size tires (2.3 pressure). Generally everything is awesome. But, after i speed up over 75 mph the "Tire Pressure Monitoring Telltale Light" turns on. Please advise me should i just ignore it or may be i should install some other TPMS or there is a way to option it?
Thanks in advance
Old Dec 19, 2013 | 07:23 AM
FSTDANGO3's Avatar
FSTDANGO3
If you are not using the Dodge TPMS sensors, available on ebay btw, you will have a few problems
STEVE
Old Dec 19, 2013 | 09:21 AM
LCF's Avatar
LCF
Aren't those sensors installed by stock?
Well if i replaced the rims and tires i need to purchase those sensors, right?
I;ll try to search for those sensors on the web and find out what that exactly is)
Thanks for the answer
Old Feb 28, 2014 | 10:06 PM
Easyryder01's Avatar
Easyryder01
Issue I'm having with my stock 20" wheel setup us that my tires excluding spare has 36lbs of pressure spare has 39lbs but the dash say 39 front and 40 rear. These pressures are all taken cold by the way.
