3rd Gen Durango 2011+ models
Plasti Dip & Wheels
Old Jan 17, 2014 | 06:19 PM
K.Ip's Avatar
K.Ip
Default Plasti Dip & Wheels
this is my first time using plasti dip. be kind
i had the polished with gloss black (which i did not want) but only RT around the area with color that i wanted. this is why i decided to give plasti dip a whirl
tips:
  • when i started the temperature was around 55 but it quickly dropped to high 30s/ low 40s (i bring this up because you are better served doing it in warmer weather)
  • be generous when spraying between the wheel and tire
  • keep your distance! otherwise, it will clump up
  • wear gloves, it gets messy
  • initial layer, instead of holding trigger, i would suggest keep "clicking" on it instead. when i was holding the trigger, i tend to over spray
items:
  • 4x cans of plasti dip (only used 2x cans for 4x layers). bought at home depot
  • microfiber rag
  • garbage bag or lots of grocery bags
  • painter's tape
  • can of dust remover
resources: google and
Prep is key! I washed the wheels. dried it the best i can and then went to home depot to get items. when i got back, i used the dust remover to blow the extra water out of the lug nuts and tire valve.
when the wheel is dry, i taped the brakes with painters tape
then i put additional grocery bags to cover brakes and rotors
i took about 10-15 min between each layer. since it was getting colder, it was taking longer and longer to dry
before:
]Name:  photo2.jpg
after:
i will be doing it again once it gets warmer. there are a few spots, where its not perfect. also, i was not generous enough between wheel and tire, so i dont have a nice layer to peel off my tire. its thin so its just kind of on there now
let me know what you think or if you have any questions
-Kevin
Old Jan 17, 2014 | 06:41 PM
fishandgrits's Avatar
fishandgrits
If you like them that's all that matters.
If you don't like them have them sprayed or powder coated. My 0.02
Old Jan 17, 2014 | 06:55 PM
ufokillerz's Avatar
ufokillerz
looks nice!
Old Jan 17, 2014 | 06:58 PM
40Cent's Avatar
40Cent
Maybe its just me- but 35K plus for a 2014 RT & you basically spray paint your rims.... Wow...... If you like it... I love it...
Old Jan 17, 2014 | 07:01 PM
JustinK.'s Avatar
JustinK.
It's the "IN" thing 40cent! People are using Plastidip on their entire cars, even high end ones.
Old Jan 17, 2014 | 08:44 PM
woblik's Avatar
woblik
I plastidipped mine with a dark gray. I like the looks. Holding up after 3 months and have even power washed em. I agree about spraying a plenty on the tire. I didnt and its a pain in the ***.
And to all the naysayers, its not always about money. This is easily removable so when i get tired of this i can peel off and do another color or just stick to the stock color.
Old Jan 17, 2014 | 08:47 PM
FSTDANGO3's Avatar
FSTDANGO3
Did you paint over the lug nuts and everything?
STEVE
Old Jan 17, 2014 | 09:34 PM
Durangerous's Avatar
Durangerous
The thing is that Plasti Dip is not paint, but rather, a coating. It is pretty durable and withstands just about everything except petroleum products and curb checks. And, if you mess it up, just peel it back and start over. What's more, it can be applied in almost any temperature. I've applied 5 coats to a wheel in under 30 minutes in sub 40 degree weather using a heat gun. In fact, I've found that no matter what the temperature, the heat gun is the way to go.
Old Jan 17, 2014 | 09:40 PM
K.Ip's Avatar
K.Ip
exactly, i can take it off tomorrow if i wanted to...
STEVE
yes to lug nuts, center cover etc..
i put tape around the valve stem
great idea with the heat gun
Originally Posted by ufokillerz
looks nice!
thanks
Old Jan 17, 2014 | 10:03 PM
Wash Man's Avatar
Wash Man
Ok, but isn't it pretty easy to throw it out of balance ?
