Suspension upgrade for Crew
Hi guys -
Do you know if the R/T has larger diameter or is stiffer than the one on the Crew? I drove an R/T and the suspension was noticeably tighter and had less body roll. Springs I'm sure are the main diff, but a Crew with a beefier Sway Bar would be sweet. No after market stuff seems to be available.
I have a 2012 5.7L Crew with AWD and Tow Package.
Would LOVE part numbers or at minimum a source to find part numbers.
Thanks!
Thanks!
Agreed - would like to put on R/T parts, but not even sure there is a difference in sway bar between the models. other threads aren't conclusive.
Part numbers or a way to find em for each model would be sweet.
thanks! do i need to swap sway bar links in addition to sway bars?
also do you know the differences in size in the front sway bars?
Trending Topics
On the Crew now:
34.66MM bar in front (call it 35mm depending on how/where you measure)
25MM in the rear
Anyone have a caliper/ micrometer that could check their R/T bar diameters?
I'm beginning to suspect that there is NO diff between Crew 5.7L AWD Tow package and R/T regarding sway bars....
25MM in the rear
