oil filter adapter leak - 2014 Durango Rallye
uggh, has anyone experienced a oil leak that they noticed under the vehicle, small oil spots noted on driveway, took vehicle into dealer yesterday, was advised leak was from the oil filter adapter, dealer installed new one, fingers crossed problem fixed....
Nope filter area, plug area are bone dry.
Just changed the oil on my 2013 Crew with V6 and found a small puddle of oil under it. Figured out that my funnel fit tight in the filler hole and while pouring in the new oil, the funnel starting filling up a bit. It seems the new oil was not draining into the motor fast enough, backed up into the funnel and at the same time it overflowed around where the funnel fit into the fill tube and leaked down the side of the motor.
Don't know if this happened to you but keep an eye on it as possible.
Kevin
Kevin
Trending Topics
I started a new thread in the "Off Topic" forum about this oil leak issue. It can potentially occur on ALL 2014 3.6L and 3.2L Pentastar V6s. The issue is that the oil filter adapter was redesigned for 2014, and it cracks.
Please post in the thread in the "Off Topic" forum if you have this issue. We need enough people to get mad at Chrysler that they redesign the part.
https://dodgeforum.com/forum/off-top...pentastar.html
