3rd Gen Durango 2011+ models
Engine turning off while driving
Old Apr 28, 2014 | 02:34 AM
MyElijah's Avatar
MyElijah
Default Engine turning off while driving
hi guys,
i have a hemi 2012 citadel, 35k km on it and been using it for over a year now here in Dubai.
for the past 2 months i've experienced engine shutting down for 5 several times while driving. the worst is it shuts down only when I'm turning to my right at a speed of approx 30-40kph. only modifications made are led lights inside and out and mgp calliper covers.
gave the car back to the dealer and awaiting for their diagnosis.
i would appreciate if someone had this experience before and share how he got out of this issue.
cheers,
Stan
Old Apr 28, 2014 | 04:04 AM
alengineer's Avatar
alengineer
same issue for 12 crew v8
Old Apr 28, 2014 | 06:55 AM
///AMG Hauler's Avatar
///AMG Hauler
I had a short in the wiring harness located under the dead pedal that would cause the same problem. I could make it happen by pressing down with my left foot as hard as possible. When it happened I would get a service AWD light that went out when it restarted. As it got worse it was harder to restart the car.
Old Apr 28, 2014 | 07:57 AM
FSTDANGO3's Avatar
FSTDANGO3
Could be a TIPM module as well
STEVE
Old Apr 29, 2014 | 08:40 AM
IEWRX's Avatar
IEWRX
STEVE
Hope not don't want to go through that again. 2011 5.7 Citadel and have had it die while driving about 5 times now. Usually when slowing for s stop of turn, left or right.
Old Apr 29, 2014 | 01:22 PM
Whiteout08's Avatar
Whiteout08
I had a similar issue, it would shut down while driving then wouldn't start right away, took about 4-5 times to restart. The issue ended up being a problem with the fuel pump relay and wiring, once replaced the problem went away.
Best of luck!
Old Apr 29, 2014 | 01:40 PM
Orin500XL's Avatar
Orin500XL
Same problem with my '12 Crew V6 with 35K miles. It happened twice, once cruising at 50mph but it restarted itself as I slowed to pullover. The other time was backing out of a parking spot. I shut everything down and it restarted on the first attempt.
I took it to the dealer but he said there were no codes. That was 6 weeks ago with no repeats.
By all means let us know what your dealer finds. I sure hope it isn't the TIPM, which will get pricey for those of us out of warranty.
